Wifi module
#51
here is the serial out...it works in every other way
I already asked it before, but I will do it again. What station name are you using here?
//   Define Name and ID's for this weather station
const char* WeatherStation_Name = "xxxxxxxxxxxx"; // Put here and identifier as your Weather Station name
I just want to check if your station is contacting the WeatherDuino server, because it seems that something is blocking connection to WU server, and perhaps to anything else except NTP servers.
I thought I did post it  IQUEENSL1244  is the station name
I sent WU a email about 2 weeks ago but had no response from them
(25-05-2018, 01:44)markkkk42 Wrote:  I thought I did post it  IQUEENSL1244  is the station name
Sorry, surely i'm being silly, but please confirm me:
IQUEENSL1244 is the name of your WU weather station, ok!
Is IQUEENSL1244 the same name used in the users configurable settings? It don't have to be, I'm just double checking.
const char* WeatherStation_Name = "IQUEENSL1244"; // Put here and identifier as your Weather Station name
Well, if the answer is yes, then your system isn't communicating nor with WU, nor with the WeatherDuino server!
In this case my best guess is for checking your router configurations. Something is blocking the attempts of the WeatherDuino to connecting to outside.
Are you sure the third dot on the top left of the screen is green? If yes, then you aren't using the IQUEENSL1244 name in the user configurable settings, but something else.
Can you please post your Config_Options.h file?
Thank you
Last time your system contacted with the WeatherDuino server using the name IQUEENSL1244 was on [2018-05-19 12:48:15].
Since then there isn't any contact. If it can't contact with the Weatherduino server surely it can't contact with WU server too.
Most probably your router is blocking it.
Hi Werk
This unit was up at my farm and it just stopped working one day uploading to WU. I have a totally different router up at my farm than I do here at home. Its a wireless broadband router a proper industrial one a Comset CM820P-W. Here at home I have Huawai broadband NBN router for high speed up to 100mb.
I have tried at both sites and it just wont upload. I am about to fire up another pro2 Plus board here this morning and see if it works. Hopefully the file attaches ok
No it
doesnt want to attach  so here is a cut and paste
//  WeatherDuino Pro2 PLUS Receiver - Version: P2AT2560_RX_v6.0_b011
//                 Start of user configurable options
// If you need help about any of the user configurable settings, please first do a search
// at the WeatherDuino Pro2 support forum. If you don't find any relevant info, then post
// a new thread.
const char* WeatherStation_Name = "IQUEENSL1244"; // Put here your Weather Station name - Don't leave this empty
const byte Station_ID = 0xA1;    // Station_ID, use the same value in all TX units
const byte Relay_ID   = 0xA3;    // Relay_ID,   use the same value in all WD units
//   Define your Weather Station location. Use decimal format for Latitude and Longitude
#define LATITUDE      -25.242    // Put here your Station latitude in degrees North (always use 3 decimal places)
#define LONGITUDE     152.072    // Put here your Station longitude in degrees - minus for West (always use 3 decimal places)
#define ELEVATION     124       // Put here your Station height above sea level in Meters (no decimal places)5
//   Define rules for Auto Summer Time Display, and clock adjustment
#include <Timezone.h>
// Example for Australia Eastern Time Zone (Sydney, Melbourne)
 TimeChangeRule aEDT = {"AEDT", First, Sun, Oct, 2, 660};    //UTC + 11 hours
 TimeChangeRule aEST = {"AEST", First, Sun, Apr, 3, 600};    //UTC + 10 hours
// Timezone myTZ(aEDT, aEST);
//TimeChangeRule PST = {"PST", Last, Sun, Mar, 1, 60};   //Portuguese Summer Time -  "UTC + 1" or GMT + 1
//TimeChangeRule GMT = {"GMT", Last, Sun, Oct, 2, 0};    //Portuguese Winter Time -  "UTC + 0" or GMT
Timezone myTZ(aEST, aEST);
//   Define Interface Language
#include "_lang/en_GB.h"      // Change the language code according to your preference. Keep "_lang/" and the ".h" at the end
                              // Currently available languages: en_GB, fr_FR, de_DE, pt_PT, es_ES, cs_CZ, nl_NL, it_IT
//   Define Roll Over Hour for Meteorological Day
const byte MeteoDay_HStart = 0;    // Use values from 0 to 23
//   Define Display Backlight TimeOut
#define BACKLIGHT_TIMEOUT    15    // Timeout for display backlight in minutes (1 to 255). 0 = Always ON
#define USE_BIGCLOCK          1    // Instead of turn off TFT backlight, show a big clock screen. 0= No, 1= Yes
//   Define data display units
#define DATE_TIME_FORMAT  0    // 0 for dd-mm-yyyy, 1 for yyyy/mm/dd
#define TEMP_DISPLAY_UNIT 0    // 0 for ºC, 1 for ºF
#define ATM_DISPLAY_UNIT  0    // 0 for mBar, 1 for inHg
#define RAIN_DISPLAY_UNIT 0    // 0 for mm, 1 for inches
#define WIND_DISPLAY_UNIT 3    // 0 for Km/h, 1 for mph, 2 for m/s, 3 for Knots
//   Define the type of your Barometric Pressure Sensor
#define BAROMETRIC_SENSOR  0   // 0= BME280, 1= BMP280 2= BMP085 / BMP180
//   Define the type of your inside Temperature / Humidity Sensor
#define INSIDE_TH_SENSOR   0   // 0= BME280, 1= HTU21D, 2= SHT21, 3= SHT31
//   Fine adjusts for Inside Temperature and Barometer
const int   TemperaturaInt_offset =   0;   // Inside Temperature Fine Adjust in Tenths of Degree (-4 = -0,4ºC)
const float pressure_offset       =   -2;   // Pressure Fine Adjust in mB
//   Define Wind Speed and Wind Gust resolution - Read carefully
// This setting only have effect when the software is used in Davis VP emulation mode
#define VP2_WIND_RESOLUTION     2    // If set to 2, set Cumulus Wind Speed and Wind Gust multipliers to 0.448. Wind Resolution 0.72 Km/h
                                     // If set to 1, set Cumulus Wind Speed and Wind Gust multipliers to 0.224. Wind Resolution 0.36 Km/h
                                     // If set to 0, system uses Standard Davis wind resolution (1 mph or 0.1mph with LOOP2).
                                     // Weather Display users should set this option to 0 - Standard Davis wind resolution
//   Define use of Wind Gust Spike prevention routines (mostly for FO anemometers)
#define WIND_SPIKECONTROL 0   // 0= Disable, 1= Enable
//   Define the source of your main outside sensors
// ---- If you are using just one TX board, the source for all items should be equal to your single TX Unit ID (most likely zero).
// ---- Define the source of your main Temperature / Humidity sensor
#define TH_SOURCE       0   // 0= Temp/Hum sensor connected to TX_Unit 0, 1= for TX_Unit 1, ..., 3 for Auriol RF Temp / Hum
// ---- Define the source of your Main Wind sensor
#define WIND_SOURCE     0   // 0= Wind instruments connected to TX_Unit 0, 1= for TX_Unit 1, ..., 3 for Auriol RF Wind Speed & Dir
// ---- Define the source of your main Rain Gauge
#define RAIN_SOURCE     0   // 0= Rain Gauge connected to TX_Unit 0, 1= for TX_Unit 1, ..., 3 for Auriol RF Rain Gauge
// ---- Define the source of your main Solar Radiation sensor
#define SOLAR_SOURCE    9   // 0= Solar Radiation sensor connected to TX_Unit 0, 1= for TX_Unit1, ..., 9 for not used
// ---- Define the source of your main UV sensor
#define UV_SOURCE       9  // 0= UV sensor connected to TX_Unit 0, 1= for TX_Unit1, ..., 9 for not used
//   Each TX unit can send data from two Temp / Hum sensors.
//   Here you must define which one will be used as your main outside Temperature / Humidity Sensor
//   SENSOR_0 can be any of the supported I2C T/H sensors (SHT31, SHT21 or HTU21D), SENSOR_1 can be an SHT1x or DHT22
#define MAINOUT_TH_SENSOR 0   // 0 for SENSOR_0, 1 for SENSOR_1
//   Define the type of your Solar Radiation device
#define SOLAR_SENSOR     2   // 1= Solar Cell "Pyranometer", 2= Apogee SP-110 Pyranometer, 3= Reserved, 4= Apogee SQ-110: Photosynthetically Active Radiation Sensor
                             // ---- Support for sensor type 4 is experimental (type 4 is a PAR sensor)
//   Define the type of your UV device
#define UV_SENSOR        1          // 1= UVM-30A, 2= VEML6075, 3= Reserved
const byte UV_Transmission = 65;    // UV Transmission percentage of UV sensor cover material.
//   Extra Sensors Settings and Mapping
// ---- Define the source and sensor type (number) for each of the seven extra sensors, insert 9 if not used.
//      Sensors SHT31, SHT21 or HTU21D are type 0, sensors SHT1x or DHT22 are type 1
// ---- Source 0 means TX unit0, 1 means TX unit1...
// ---- Source 6 (Reserved)
// ---- Source 7 is for BIOS Sensor (Only Temperature is shown)
// ---- Source 8 is for Temperature/Humidity from the Air Quality Monitor
// ---- First field = Sensor source, Second field = Sensor type (0 or 1 for TX units)
// ---- Example:
// ----                          ES0   ES1   ES2   ES3   ES4   ES5   ES6
//#define EXTRASENSORS_SOURCE { {0,1},{1,1},{9,9},{6,3},{9,9},{8,0},{9,9} }
//               {0,0} - First extra sensor (ES0), will be sensor 0 from TX unit0
//               {0,1} - Second extra sensor (ES1), will be sensor 1 from TX unit0
//               {1,0} - Third extra sensor (ES2), will be sensor 0 from TX unit1
//               {9,9} - Fourth extra sensor (ES3), not used - not mapped
//               {9,9} - Fifth extra sensor (ES4), not use - not mapped
//               {8,0} - Sixth extra sensor (ES5), will be Temperature / Humidity from the Air Quality Monitor
//               {9,9} - Seventh extra sensor (ES6), not use - not mapped
//-----                        ES0   ES1   ES2   ES3   ES4   ES5   ES6
#define EXTRASENSORS_SOURCE { {9,9},{9,9},{9,9},{9,9},{9,9},{9,9},{9,9} }
// ---- Define personalized names for each Extra sensor. Attention, 8 chars maximum
// ---- There is no need to define a name for the Extra Sensor mapped to the Dust Density / AQI index data
//                   Max. Size  [--------]
const char ESname_1[] PROGMEM = "";            // 8 chars max
const char ESname_2[] PROGMEM = "";            // 8 chars max
const char ESname_3[] PROGMEM = "";            // 8 chars max
const char ESname_4[] PROGMEM = "";            // 8 chars max
const char ESname_5[] PROGMEM = "";            // 8 chars max
const char ESname_6[] PROGMEM = "";            // 8 chars max
const char ESname_7[] PROGMEM = "Dust TH";     // 8 chars max
//   BIOS soil moisture sensor settings
// ---- Please use the included BIOS_ID_Scanner sketch to find you BIOS Device ID
#define BIOS_SENSOR_ID   0       // Device ID in HEX format, or 0 not used
//   Soil / Leaf Interface Settings and Sensors Mapping
//   (The mapping logic is the same than used with the Extra Sensors)
// 0 = Soil Leaf Interface not used
// 1 = Soil Leaf Interface connected to a TX unit
#define SOIL_LEAF_INTERFACE  0   // 0, 1,
// ---- For Soil & Leaf data from SoilLeaf_Interface wired to a TX unit, use TX Unit number as source
// ---- For BIOS Soil Temp / Moisture use 7 as source
// ---- To disable use 9 in both fields
//                                 S1    S2    S3    S4
#define SOILTEMPSENSORS_SOURCE  { {9,9},{9,9},{9,9},{9,9} }
#define LEAFTEMPSENSORS_SOURCE  { {9,9},{9,9},{9,9},{9,9} }
#define SOILMOISTSENSORS_SOURCE { {9,9},{9,9},{9,9},{9,9} }
#define LEAFWETSENSORS_SOURCE   { {9,9},{9,9},{9,9},{9,9} }
// ---- Define personalized names for each Soil and Leaf sensor. Attention, 8 chars maximum
//              Soil Max. Size  [--------]
const char SSname_1[] PROGMEM = "1";        // 8 chars max
const char SSname_2[] PROGMEM = "2";        // 8 chars max
const char SSname_3[] PROGMEM = "3";        // 8 chars max
const char SSname_4[] PROGMEM = "4";        // 8 chars max
//              Leaf Max. Size  [--------]
const char LSname_1[] PROGMEM = "1";        // 8 chars max
const char LSname_2[] PROGMEM = "2";        // 8 chars max
const char LSname_3[] PROGMEM = "3";        // 8 chars max
const char LSname_4[] PROGMEM = "4";        // 8 chars max
// Define VWC calculation method
// Method 1 applies only for VH400 soil moisture sensor
// METHOD 1 - Conversion from voltage to VWC (volumetric water content) is done using the piecewise regressions provided by the manufacturer
// at http://www.vegetronix.com/Products/VH400/VH400-Piecewise-Curve.phtml
// METHOD 2 - Used for any sensor which have a linear output between voltage and VWC (0V=0VWC, maxV=100VWC) .
#define VWC_CALCMETHOD   1  // 1 or 2
// Max and Min output voltage of the analog sensors connected to Soil / Leaf Interface
// Default value for Decagon Devices LWS Leaf Wetness Sensor (3.3V power): Max. Output Voltage - 1395mV (max wetness), Min Output Voltage - 530mV (dry)
//                                                  ADC1  ADC2  ADC3  ADC4
const uint16_t AnalogSensor_MaxVoltOut[4]   = { 3000, 1395, 5000, 5000 };    // Values in miliVolts
const uint16_t AnalogSensor_MinVoltOut[4]   = {    0,  530,    0,    0 };
//   Broadacasting settings for Wireless Display Units
#define RELAY_DATA       1   // 0= Disables Data Relay, 1= Enables Data Relay
//   Davis compatible Data Logger Settings
#define LOGGER_ENABLE    1   // 0= Disable 1= Enable
byte ARCHIVE_PERIOD  =   5;  // Default Archive Period in Minutes (Usable values: 1, 5, 10, 15, 30)
//   Define type of your Weather Software
#define WEATHERSOFT      0   // 0= CumulusMX, 1= Any other (Cumulus 1, WeewX, Weather Display, etc.)
//   Easyweather Mode output
#define EASYWEATHER_OUT  0   // 0= Disable (defaut) 1= Enable
//   Internet Settings
#define ENABLE_INTERNET     1                        // 1= Enable Internet connection, 0= Disable
// ---- NTP Settings ----
#define ENABLE_NTP          1                        // 1= Enable Sync time with NTP servers, 0= Disable
// NTP Servers:
//#define TIMESERVER "pool.ntp.org"
//#define TIMESERVER "time.nist.gov"                 // ntp1.nl.net NTP server
#define TIMESERVER "80.96.196.58"                  // timp.mcsi.ro
//#define TIMESERVER "193.79.237.14"                 // ntp1.nl.net NTP server
// ---- Weather Wunderground Settings ----
#define ENABLE_WU_UPLOAD   1                         // 1= Enable upload to Wunderground, 0= Disable
#define WU_UPLOAD_INTEMP   1                         // 1= Enable upload of Inside Temperature / Humidity, 0= Disable
byte    WU_upload_period = 3;                        // Period in minutes between uploads to WU (Should be >= 3 minutes, if less defaults to 4 minutes)
// ---- Air Quality Monitor - Upload to ThingSpeak Settings ----
#define ENABLE_TS_UPLOAD         0                   // 1= Enable, 0= Disable
// ---- Air Quality Monitor - Upload and insert data in a SQL table at your own server ----
// ---- Database and table must be created first. See AirQuality_LogToSQL.php script for info
#define ENABLE_AQM_TO_MYSERVER    0                  // 1= Enable, 0= Disable
// ---- Web Server Settings ----
#define ENABLE_WEBSERVER          1                  // 1= Enable 0= Disable
#define WEBSERVER_PORT           80                  // WebServer port (default 80)
//   Enable / Disable GPIO routines - General Purpose Input / Output ports
#define USE_GPIO  0   // 0=Disable, 1= Enable
//   Define display order of data screens on the TFT
//   Use sequentially numbers from 1 to 4.
#define AirQuality_Data    1
#define TXinfo_Data        2
#define ExtraSensors_Data  3
#define SoilLeaf_Data      4
//   Test Mode : Never run a live system in test mode
bool Test_Mode = false;    // false= Normal working mode, true= Test mode only (no logger, no usb connection)
//     Hardware Settings
//   Define PCB Version Number
//                              Take particular attention to this setting.
//                              Your system may not work properly if you define a wrong pcb version number.
//                              In case of doubt check what is printed in your pcb.
#define PCB_VERSION   13   // PCB version number, without the decimal point Ex: 1.3 = 13 (integer number)
//   Define your Display type
#define DISPLAY_TYPE     3    // 1= LCD 20x4, 3= TFT 320x240 ILI9341
//   Define LCD I2C address
// Only change this if your LCD don't display any data. I2C_Scanner utility may help you to find the address of your LCD display
#define LCD_ADDRESS      0x27
//   SHT31 I2C Address - Default address will work most of the times!
#define SHT31_ADDRESS       0x44       // Default value is 0x44, but it can be changed to 0x45
//   Presure Sensor Address (no need to change)
//#define BMP085_ADDRESS    0x77       // I2C address of BMP085 or BMP180
//   Debug helper
//#define PRINT_DEBUG_WIFI
//#define PRINT_DEBUG_NTP_UPDATE      // Prints to serial monitor messages related to sync time with NTP server
#define PRINT_DEBUG_WU_UPLOAD       // Prints to serial monitor messages related to Weather Underground upload.
//#define PRINT_DEBUG_TS_UPLOAD
//#define PRINT_DEBUG_MYSERVER_UPLOAD
//#define PRINT_DEBUG_VCHECK
//#define PRINT_DEBUG_TCP_SERVER
//#define PRINT_DEBUG_AURIOL
//#define PRINT_DEBUG_BIOS
//#define PRINT_DEBUG_RF_MESSAGES
//     End of user configurable options
Ok... I put a new arduino board into the original pro plus2 motherboard and it would not log on. I have just made up the second spare board I had here and put the same 2560 that I had in the original and powered it up and after a couple of minutes...BANG its back on WU..so the issue must be on the motherboard or in the wifi module
I have 3 green lights on the display now and just checked WU and it is back on there as well
Well, its hard to understand why one of the WiFi modules can get Wifi Connection, can connect to an NTP server, but is unable to connect to an http server as is the case of WU.
By sure it isn't any problem with the board, otherwise it don't even communicate with the WiFi module to establish the WiFi connection, or to sync the time from the NTP server.
A real mystery.
Hi Werk
if anything gets crazy it will happen to me.  I have ordered some spare modules they are dirt cheap locally here in Oz so when it arrives I will replace it and see what happens. I am taking this time to get the one for home here setup in a box using for the moment the FO sensors I have from the cheap station I got here. i have tested them and they seem to work ok. I have a SHT31 board which I have utilizes the original sun/temp housing of the cheap system into so hopefully maybe even up and going tomorrow
