"New" Wireless Display
I'd like to confirm the full functionality of the latest release WeatherDuino 4Pro Wireless Display v3.0_b006 - 2018-04-24,
especially in the Czech language! It works without any issues. I thank the author for (traditionally) perfect job!   Smile Heart
(There is a small mistake in translate of one day to Czech language at the WeatherUnderground web ...  Wink
Thank you Zdenek.
By now, some Wireless Display units should already arrived at their destination. I would like to hear some feedback from their users. This is an completely new device, user opinions are even more important.
WeatherDuino Software started to be so stable that almost no one writes on the Forum, I should think about it...  Idea  Smile One or two bugs seems good to keep forum activity!
Okay, we'll have to figure out bugs ...  Big Grin
Tonight I successfully updated my Wireless Display unit to the latest release WeatherDuino 4Pro Wireless Display v3.0_b006 - 2018-04-24,
This was also the first time I used the "Over The Air" (OTA) method of updating the wireless display, it worked surprisingly well.
I did need to do some extra reading on how to set this function up and found this link most useful - http://esp8266.github.io/Arduino/version...dates.html . Before reading this, I had installed "Python 2.7" without "Add python.exe to Path" installed. This by default is not installed and needs the user to select it.
I think one of the best features of this display is having the localised weather forecast icons. Best of all, this forecast is from MY weather station through Weather Underground - a truly unique feature.
I also like having the seconds tick by on the clock; this could be a useful timing piece for other work I do.
Having the "Receiver Location T/H" temperature/humidity displayed on the "System Information" page is a nice addition as it allows the wireless display to have its own unique temperature sensor while still being able to see what the main receiver's temperature is - ideal for if they are in different rooms.
As part of the development, maybe a "dark clock" mode could be developed for the "big clock" display. Sadly it is not possible to dim the LCD backlight through software, but using dark colours, closer to the black background, could help make the display appear darker without actually needing to physically dim the display. Could be useful for dark rooms like bedrooms at night.
In the coming weeks I will have my unit in an enclosure and intend to use it on a beside table.
Everything is good here too and just updated the software. I echo what everyone else has said. OTA capability is brilliant. Congratulations Werk and thank-you Smile
(26-04-2018, 10:46)Palmyweather Wrote:  I did need to do some extra reading on how to set this function up and found this link most useful - http://esp8266.github.io/Arduino/version...dates.html . Before reading this, I had installed "Python 2.7" without "Add python.exe to Path" installed. This by default is not installed and needs the user to select it.
[Image: attachment.php?aid=1406]
Thanks Palmyweather, indeed this info is important. I added the above image to the basic installation instructions.
Quote:As part of the development, maybe a "dark clock" mode could be developed for the "big clock" display. Sadly it is not possible to dim the LCD backlight through software, but using dark colours, closer to the black background, could help make the display appear darker without actually needing to physically dim the display. Could be useful for dark rooms like bedrooms at night.
Of course we can change the "big clock" to darker colours during night time, but there is also another solution... instead of a simple backlight switch, you can use a 3 position switch plus a resistor, and have two personalized TFT backlight levels Idea , plus OFF.
(26-04-2018, 11:27)qldbureau Wrote:  Everything is good here too and just updated the software. I echo what everyone else has said. OTA capability is brilliant. Congratulations Werk and thank-you Smile
Smile Yeah, I love OTA too.
(26-04-2018, 19:51)Werk_AG Wrote:  ... instead of a simple backlight switch, you can use a 3 position switch plus a resistor, and have two personalized TFT backlight levels  Idea  , plus OFF.
Of cause! That makes so much more sense, that could be easily done across the backlight pins by removing the jumper. I had only considered this as a two state position. Big Grin
Smile  The two pins intercepts the TFT backlight power line, so even a potentiometer can be used.
Hi Werk
I just wanted to let you know that I received my new Wireless Display the other day and can confirm it is working well and I have just managed to do the OTA update. Everything is working well. Now just need to see if I can get a nice enclosure for it.
Chris
Users browsing this thread:
