Threads: 66
Weather Station: Melton Hill North Ward
Another small issue I noticed today on my WD. The fan status either says OFF or ONF
may be a coding issue.
Jim,
And the FAN Led on the TX unit is also switchin ON and OFF?
There isn't any coding issue with the software.
As I already said, trying to get conclusions until you have all the system assembled (RX and TX) and connected with the required outside sensors (Wind, Temp / Hum, rain gauge) can give you unpredictable results. Each unit don't work independently.
Threads: 66
08-09-2016, 08:19
(This post was last modified: 08-09-2016, 08:24 by
Barrow4491.)
Hi all,Well at long last I have some time to post some photos of my long winded construction, which believe me I have enjoyed immensely.
As I stated before I have relatively easy access to my roof via an opening skylight so I mounted my mast and transmitter up there, and because we live in a cyclone rated area (at least according to our insurance company) I decided to mount the mast on the solar hot water system brackets which were designed to withstand cyclonic winds.
Because of the potential high wind speeds I decided to go with Davis anemometer and rain gauges which appear to be of better quality construction than the Fine Offset units (if price is any guide).I have attached photos of various components (Radiation shield with SHT 31D and fan), TX enclosure and board, and solar UV unit (imitation is the sincerest form of flattery; Thanks uncle_bob).
I am wailing for fused silica glass to finish it and it will mount on the front of the rain gauge.
My Tx unit is mains operated with battery backup and automatic change over to solar panel charging in the event of mains failure.
That just about covers the TX side of things and I must express my thanks for all the assistance given without question to some of my issues throughout construction.
Werk, the concept is brilliant and appears to be ever evolving!! Thanks again.
Kind regards
It appears there is a limit for images in a post so I have added a couple more here.
Next will be my Rx unit
Jim, thanks for the pictures. Installation looks good, congratulations!
Threads: 8
Weather Station: Olivier - PHOTOGRAPHIES
Great job Jim, looks cool !
Threads: 14
Weather Station: Zillmere Weather - Brisbane, AU
Hi Jim, Just looking over the photos of your build and installation. Top work, and very neatly done... Now that its been a few months, how is it all running..????
Mark R
