Threads: 337
Country:
Please copy and paste here the content of your Config_WD.h
and tell me if you have any local TH sensor connected. In affirmative case, what type? DHT22 or HTU21D?
Threads: 337
Country:
Is the clock running in the RX unit?
Threads: 337
Country:
Jim,
It's true that the clock will be set to the right time and data an soon as you connect the RX unit with Cumulus, but first you need to have a fully working TX unit, however as said by Uncle_Bob on post #5, you can "manually" set the clock, using an Arduino sketch included in the RTC library. Look at the examples folder, compile and upload the ds3231 sketch, it will set the clock, after that compile and upload again the WeatherDuino Pro2 RX software.
I understand the temptation to try a partially assembled system, but doing it can give you unpredictable results. Keep cool, at the end, everything will work as expected. You did a good progress so far, and I will try to help as much as I can.
As the ATM is sent to the WD units in the second zero of each minute, have the RTC running is crucial for it to happen.
Threads: 66
Country:
Thanks for the information re the RTC. I will swap it out when the replacement arrives; I remember reading somewhere in the forum to mount it horizontally with the battery upright?? Is this important as it is difficult t with the later version of the RX board
