07-09-2016, 06:59
Could someone guide me with initial station settings for Cumulus MX. I am installing it on a Raspberry Pi 3
(07-09-2016, 08:05)laulau Wrote: There's a thread in software section about that
http://www.meteocercal.info/forum/Thread...figuration
(07-09-2016, 23:47)Barrow4491 Wrote: Thanks for that I have read it but still have a few questions
TCP/IP settings
IP address ( Di I put in the address of the pi)
TCP port (22222 or change it to something else)
Disconnect period ??
Serial port name ??
Log interval ??
Log rollover 9am or midnight
(08-09-2016, 00:06)hornychz Wrote:(07-09-2016, 23:47)Barrow4491 Wrote: Thanks for that I have read it but still have a few questions
TCP/IP settings
Serial port name ??
Log interval ??
Hi, this is my:
(08-09-2016, 00:22)Barrow4491 Wrote: Is it possible to get the rest of the settings file?
Are you running your pi 24/7 or starting daily. I am sorry for the questions but I am new to Linux and Cumulux
PS I hope to post my photos etc if time permits today or tomorrow
(08-09-2016, 00:38)hornychz Wrote:Thanks for that I seem to have it sorted now, with the only issue the barometric pressure gauge only reads to 1050 and the local pressure is about 1018. Do you know if it can be altered in the .ini file or will go to the ss forum.(08-09-2016, 00:22)Barrow4491 Wrote: Is it possible to get the rest of the settings file?
Hi again,
and yes - the system is running continuously without reboots.
And here is my Cumulus.ini file (shorted and without credentials).
Good luck.
(09-09-2016, 05:36)Barrow4491 Wrote: ... with the only issue the barometric pressure gauge only reads to 1050 and the local pressure is about 1018. Do you know if it can be altered in the .ini file or will go to the ss forum.
