Cumulus MX station settings - Printable Version
+--- Thread: Cumulus MX station settings (/Thread-Cumulus-MX-station-settings)
Cumulus MX station settings - Barrow4491 - 07-09-2016
Could someone guide me with initial station settings for Cumulus MX. I am installing it on a Raspberry Pi 3
RE: Cumulus MX station settings - laulau - 07-09-2016
There's a thread in software section about that
http://www.meteocercal.info/forum/Thread-v2-0-Software-Cumulus-1-and-CumulusMX-configuration
RE: Cumulus MX station settings - Barrow4491 - 07-09-2016
(07-09-2016, 08:05)laulau Wrote:  There's a thread in software section about that
Thanks for that I have read it but still have a few questions
TCP/IP settings
IP address ( Di I put in the address of the pi)
TCP port (22222 or change it to something else)
Disconnect period ??
Serial port name ??
Log interval ??
Log rollover 9am or midnight
I am OK with location etc and the rest
RE: Cumulus MX station settings - hornychz - 08-09-2016
(07-09-2016, 23:47)Barrow4491 Wrote:  Thanks for that I have read it but still have a few questions
TCP/IP settings
Serial port name ??
Log interval ??
Hi, this is my:
[Image: CumulusMX_conf.jpg]
RE: Cumulus MX station settings - Barrow4491 - 08-09-2016
TCP/IP settings
Serial port name ??
Log interval ??
Hi, this is my:
Hi,Thanks for your prompt reply.
Is it possible to get the rest of the settings file?
Are you running your pi 24/7 or starting daily. I am sorry for the questions but I am new to Linux and Cumulux
PS I hope to post my photos etc if time permits today or tomorrow
(08-09-2016, 00:22)Barrow4491 Wrote:  Is it possible to get the rest of the settings file?
Hi again,
and yes - the system is running continuously without reboots.
And here is my Cumulus.ini file (shorted and without credentials).
Good luck.
RE: Cumulus MX station settings - werk_ag - 08-09-2016
(07-09-2016, 23:47)Barrow4491 Wrote:  Log rollover 9am or midnight
Hi Jim,
The time of day rollover is your choice, but I think that in your region the 9am rollover is the standard. No matter what option you choose don't forget to set the same value in your Config_RX settings.
RE: Cumulus MX station settings - spudstrawb - 08-09-2016
Obviously the 9am changeover is a hangover from the past, when weather stations (rain gauges in particular) were monitored manually. I'm in Australia but I've set my weather station to rollover at midnight. I want to know how much rain fell on a certain day, not between 9am on one day and 9am on the next day.
BTW, I have 8998 as my TCP port setting.
RE: Cumulus MX station settings - Barrow4491 - 09-09-2016
Hi again,
Good luck.
Thanks for that I seem to have it sorted now, with the only issue the barometric pressure gauge only reads to 1050 and the local pressure is about 1018. Do you know if it can be altered in the .ini file or will go to the ss forum.
thanks again for your assistance
RE: Cumulus MX station settings - werk_ag - 09-09-2016
(09-09-2016, 05:36)Barrow4491 Wrote:  ... with the only issue the barometric pressure gauge only reads to 1050 and the local pressure is about 1018. Do you know if it can be altered in the .ini file or will go to the ss forum.
The fact that the CumulusMX pressure gauge shows a maximum scale value of 1050, is not an issue. In the unlikely case of the ATM at your location, rise above that value the gauge will adapt itself.
Just by curiosity:
The highest adjusted-to-sea level barometric pressure ever recorded on Earth (above 750 meters) was 1,085.7 hectopascals (equal to mB) measured in Tosontsengel, Mongolia on 19 December 2001.
The highest adjusted-to-sea level barometric pressure ever recorded (below 750 meters) was at Agata, Evenkiyskiy, Russia [66°53’N, 93°28’E, elevation: 261 m (856.3 ft)] on 31 December 1968 of 1,083.8 hectopascals.
Source: Wikipedia
