Just thought an idea of posting different wind vanes and anemometers with a note of the output values, as far as I can see for wind vanes there are two types;
a) Fine offset type resistors on a board
b) potentiomemter type as per Davis with potentiometer of various values, 1Kohm (didcot being 1Kohm (SAKAE LNB22)) I have found and 20Kohms more usual ie Davis (Bourns 6639 20K potentiometer 360º turn no stop)
Anemometers:
a) Reed switches one or two clicks per revolution
b) Voltage output ( 0 to 1 or more volts)
c) Current output (4-20ma)
d) Hall effect
e) optical tachometer type
We could slowly develop this thread; if it is OK by Werk, and perhaps someone could look at suitable code changes to allow these sensors to be used, to allow us to use these often very high quality sensors occasionally found on ebay from old research projects.
Didcot:
From the mid 1980's to mid 1990's
Very high quality:
Anemometers:
Various configurations, current, voltage and reed switch.
NRG Anemometers:
https://www.renewablenrgsystems.com/prod...anemometer
Many types; Hall effect; voltage output and current output.
Occasionally available at end of wind turbine project surveys
Davis Weather 7911 anemometer and vane.
Reed switch (one click per rev) and 20Kohm potentiometer.
Available on ebay for about £75.00, bomb proof, mine has put up with Scottish wind for 6 years without any trouble.
http://www.ebay.co.uk/itm/Davis-Instrume...43cfe968a5
Anemometers:
d) Hall effect
Didcot:
Very high quality:
Anemometers:
NRG Anemometers:
