Threads: 4
I have a Pro2 Compact which is working great with the TX! So I've put in the correct WU station ID and password in Credentials.h, and changed ENABLE_WU_UPLOAD to "1" in Config_Options.h, but still nothing is being sent to Weather Underground. The middle "led" in the top left of the RX display is red, which I think indicates it isn't in contact with Wunderground. What can I do to get this to connect?
Threads: 27
Weather Station: WeatherDuino Pro2
Have you put your router details into credentials:
WiFi Credentials
const char* WIFI_SSID = "ABCD_DEF_34";
const char* WIFI_PASSWORD = "12345678";
Check SSID especially
Threads: 4
Yes, the rx is connected to the Wifi no problem, I can see the weather at "ip.address/weather" and I've put the station key in the password, not my wunderground password
Please check if you are using the latest ESP8266 board manager, which is 2.7.1. If not, upgrade the boards manager.
Don't forget to choose as Flash size 4M(FS:1Mb OTA ... )
After upgrading boards manager you need to upload the fonts and icons again, using the ESP866 Sketch Data Upload.
Now compile the code and upload it the usual way.
