Threads: 8
Country:
11-10-2022, 12:49
(This post was last modified: 11-10-2022, 14:52 by
gtbwise.)
Hi all
my soldering station is a Yihua 8786D - i believe it is rated at 50w
will that be suitable to use for my project ?
thanks
geoff
Threads: 8
Country:
reading manual it seems i can get the following from the iron
Work voltage 26V±10% 50Hz/60Hz
Temperature range 200 °C ~480 °C
Temperature stability ±2 °C (Static state)
Tip-to-ground impedance <2Ω
Tip-to-ground voltage <2mV
geoff
Threads: 8
Country:
on inspection i found the ceramic heating core was broken on the iron, so i have ordered 2 new ones and a range of tips (10)
the unit also has the air gun which might come in handy
geoff
Threads: 337
Country:
The power of your soldering iron is good for the job, the most important is using a thin tip.
