18-01-2020, 23:43
Hi, now I downloaded and compiled the new version v2 of the Wireless_sensor module. I doing some tests.
Thank you
Thank you
// Test Mode : Never run a live system in test mode
bool Test_Mode = false; // false= Normal working mode, true= Test mode only (no usb connection)(18-01-2020, 23:37)Werk_AG Wrote: Hi bigcakeHi Caniera, i didn't make factory reset, i have do that now.
Regarding the rain issue, having you did the factory reset (not the same thing than resetting the D1) as stated on my first reply?
Quote:I also suggest that you try to perform a factory reset of the receiver. Go to Menu (touch on the upper left side of the screen) then you will see a button for that purpose. Touch it. After some seconds (up to 10s) unit should reboot itself, however if after 10 seconds it haven't reboot, then press the D1 reset button.
Does the rainfall rate which is shown on the screen of the receiver also changes as happens on your graphs? Do you have any Cumulus graphs where the Rainfall Rate shows the same behaviour?
Regarding the temperature freezes, you could do the same procedure explained on the post above. Replace the Wireless_Sensors.ino file by the one which is attached some post above.
Up to now I has unable to reproduce the described issues with my Auriol weather station, that's why I ask for feedback.
(19-01-2020, 00:12)Werk_AG Wrote: A silly question, but perhaps important. Are you running the receiver in test mode?
Code:// -------------------------------------------------------------------------------------- // Test Mode : Never run a live system in test mode // -------------------------------------------------------------------------------------- bool Test_Mode = false; // false= Normal working mode, true= Test mode only (no usb connection)
(19-01-2020, 00:21)Werk_AG Wrote: Good, thanks.
(19-01-2020, 00:48)bigcake Wrote:(19-01-2020, 00:21)Werk_AG Wrote: Good, thanks.
It just happened after the factory reset and the new v2 module:
the temperature went from 3.7 ° C to - 83.2 ° C. After twenty seconds it returned to 3.7 ° C
It then remained for a while at 3.7 then rose to 121.6 while I am writing to you and then returned to 3.7 which is the real value
Quote:rainin - [rain over the past hour)] -- the accumulated rainfall in the past 60 min
dailyrainin - [rain so far today in local time]
