(02-01-2015, 17:22)Werk_AG Wrote: designs and software beta releases are available to Developers / Testers, months before they are publicly released.
So, uncle_bob already have the software since sometime...
Yes Sir, I understand. I just wanted to be clear on what I was actually looking at since it looked like a normal RX board to my eyes.
(02-01-2015, 09:12)Live_Steam_Mad Wrote: Glad that you got it working and setup to your liking. BTW does your TMP36 still read 70-ish? Did you ever solve that problem?
(02-01-2015, 17:22)Werk_AG Wrote: What do you mean with this? Please bear in mind that English is not my natural language, and I have difficulty in understanding some expressions.
I understand about the latter part. I cannot hardly speak any other languages. Personally I think your English is of a very good standard indeed.
By "still read 70-ish", I was referring to a time when uncle_bob was seeing values coming from (I assumed) his TMP36 which were e.g. 71,72,73...79 Farenheit or similar values approx., and he thought there was a problem with it, he described it here ;-
http://www.meteocercal.info/forum/Thread...163#pid163
...to quote uncle_bob ;- "I've also replaced the TMP36. Still reading in the 70's.", and from post #44 ;- "I believe the TMP36 is actually reporting Fahrenheit instead of Celsius"
...and there was no more mention of it from your or him in this topic so I was just curious as to whether the problem was solved?
(02-01-2015, 23:02)uncle_bob Wrote: You may have to cast your mind back awhile, The problem with the TMP36 was that the data output was different to the LM36 (LM36 can not read negative temperatures)
You mean you had installed an LM36 instead of a TMP36 ? Or do you mean that you were using programming code that assumed the presence of an LM36 and that you had a TMP36 installed instead?
(03-01-2015, 00:08)Werk_AG Wrote: Hi uncle_bob
That problem was corrected since you discovered it long time ago.
Just in case, I have checked the last software release, and it's set for the TMP36. Is it not working for you?
(03-01-2015, 00:19)uncle_bob Wrote: Hi Werk, Yes that problem was fixed ages ago.
Alistair was just checking
Cheers Bob
Ahh good, problem was solved. Excellent.
ARG
www.wunderground.com/personal-weather-station/dashboard?ID=IENGLAND609
Fine Offset WH-1081 (Maplin N96FY) at present, soon to be WDPro2 I hope so that I can have Solar & UV graphs as well
