I'm spending entirely too much time on this topic but it is what it is.
I called the ARRL and they didn't have much to say because the arduino transmitters aren't ham radio items. Was also told that arduino transmitter modules did not need FCC type acceptance because it is not a finished product, it is simply a part intended to be used with a collection of parts. He also mentioned there are regulatory provisions for hobbyists, which is what I remembered reading previously. Googling that further I found the following which hopefully will put this topic to rest, at least for those of us in the USA.
Part 15.23
Home-Built Transmitters that are Not for Sale
Hobbyists, inventors and other parties that design and build Part 15 transmitters with
no intention of ever marketing them may construct and operate up to five such
transmitters for their own personal use without having to obtain FCC equipment
authorization. If possible, these transmitters should be tested for compliance with the
Commission's rules. If such testing is not practicable, their designers and builders are
required to employ good engineering practices in order to ensure compliance with the
Part 15 standards.
These can be used between 410-470MHz with emissions limits, however, testing is not required as per Part 15.23 but good engineering practices should be employed,with the all encompassing caveat that it may not create interference and must accept interference.
So to summarize. In the USA you can use up to 5 unlicensed non-type accepted transmitters for your own personal use as long as you aren't selling them. And if you're that concerned about emissions limits (that anyone still curious is welcome to google for themselves) then feel free to spend the thousands of dollars required to comply with something you're not expected to test for anyway.
Part 15.23
Part 15 standards.
Good job, danner!
![[Image: HFBR-1712TZ.jpg]](http://media.digikey.com/Photos/Avago%20Tech%20Photos/HFBR-1712TZ.jpg)
