I'm really impressed with WeatherDuino and it fits in well with my plans to replace my old Davis weather station. However the choice of wireless frequency is inappropriate for use in the USA.
In the USA, 433MHz is nearly in the middle of the 70CM amateur radio band. Legally, any transmissions on that frequency can only be made by a licensed amateur radio operator. Anyone transmitting on that frequency without holding a valid amateur radio license is in violation of Federal Communications Commission (FCC) rules and is subject to hefty fines if caught. The FCC doesn't drive up and down streets trying to detect transmissions of a few miliwatts on 433 MHz so it can dish out a fine. However, the 433 MHz transmitters used by WeatherDuino aren't known for frequency stability or doing a good job of suppressing unwanted harmonics of 433 MHz. If one's WeatherDuino transmissions annoy a nearby amateur radio operator or its insufficiently suppressed 866MHz second harmonic invades the radio system of your local police department, they are well within their right to file a complaint with the FCC and expect an investigation, remediation and punishment.
There are transmitter and receiver parts with identical footprints and interface characteristics that operate on 315 MHz. Operation on this frequency falls within the FCC rules allowing low power remote control and data exchange. In the USA garage door openers, vehicle remote controls, personal weather stations and wireless cooking thermometers among others use 315 MHz and adjacent frequencies. Anyone in the USA contemplating building a WeatherDuino should purchase the 315 MHz version and anyone in the USA with an operational WeatherDuino should replace the 433 MHz transmitters/receivers. The transmitter/receiver pair can be purchased for $1 or less on eBay so cost shouldn't be an issue. If problems do develop with the transmitter operating out of spec the FCC is much more forgiving if one is operating on an appropriate frequency. Currently the second harmonic of 315 MHz falls within USA TV channel 40 and after the FCC finishes reshuffling all the TV channels in the country to 36 or less, it will be within a cellular phone band. Either one is much less likely to incur somebody's wrath.
George Bean
Amateur Radio Operator - AI4VJ
George Bean
