Threads: 27
Weather Station: Alma, MI USA
11-10-2017, 23:44
(This post was last modified: 11-10-2017, 23:46 by
danner.)
Among the other hobbies I do is amateur astronomy so I'm quite aware that there is light from the sun before the sun comes up and after it goes down. How sensitive the sensor is to the small light levels is something I do not know yet, but hopefully will understand soon. Which lead me to another examination of what is behind the readings I am getting at night.
Something else I was looking at was whether the full moon could possibly trigger the sensor as it is quite bright and high in the sky. There is some correlation in the solar readings (the spec sheet says it's a type of photo-diode, which I was able to get output from by shining my flashlight on it) with the full moon rising and the higher in the sky the moon is the higher the readings above 1 W/m2 become. But I am also aware that correlation does not equal causation, that it could simply be a coincidence. I wont know if there is any correlation until the moon cycles and isn't out at night, or I could climb on my roof and put the black cloth on the sensor.
Threads: 0
12-10-2017, 02:05
(This post was last modified: 12-10-2017, 02:12 by
AllyCat.)
I've been watching this thread, but stayed out because, although I understand (some of) the theory, it's a very complex subject and I'm in danger of writing pages and pages.... Also, I suspect that it's fundamentally a "physical" problem, but don't have much of an idea what the cause might be. So just a few brief comments for now:
For photography, one unit of light level is the Lux, with full sunlight being approximately 100,000 Lux. But moonlight is less than 1 Lux (i.e. >100,000 times smaller) so if we apply that to the 300 mV full-scale from the SP-110 we would expect only a few microVolts in moonlight. Those voltage levels are very difficult to measure because of "noise" and thermoelectric effects. That just might be the cause of your problem - junctions between different metals at different temperatures can generate a (small) voltage difference.
The light (or energy) level that we're trying to measure is proportional to the current which is generated (and actually it's not too difficult to measure a current ratio of 1: 1 Million, or more). However, voltages are generally easier to "understand" and measure, and the conversion is easy - it's what a resistor does (V = I x R) ! Werk puts the resistor directly on the (PV) sensor (as presumably do Apogee) whilst Davis effectively amplify the current first and then convert to a voltage.
The voltage gain is indeed (almost) proportional to the feedback resistance (ratio). So for the very best stability (but not as convenient), the "Pot" could be replaced by a Metal Film (fixed) resistor (perhaps re-using the pot to balance the Input Offset) and the gain adjusted purely within the software.
It's worth considering the specification of the Op Amp: The "Input Offset Voltage" can be several hundred microVolts, which represents an "error" in the input voltage, that gets multiplied by the amplifier gain to produce an output that might represent several watt/m2. Also, although it is a "rail to rail" device, it cannot pull the output completely down to zero (milli-) Volts. The data sheet specifies about 6 mV at 20 microamps (pull-up), but I can't see why the current would be even as large as that. However, I do wonder if the designers of the SP-110 expected it to be used with a true "instrumentation grade" (i.e. very expensive) amplifier.
Probably! Try it.
Setting the "clipping" to 4 or 5 will be safer.
Avoid setting R2 above 4900
