Apogee SP-110
I just snagged an Apogee SP-110 pyranometer off of ebay. I think I got a pretty good deal for it, but I guess the jury is still out until I get it connected and running. Big Grin
He has 9 more for sale. In case anyone is interested the ebay link is here. http://www.ebay.com/itm/302444132379
Looking at the manual there are 3 wires
Red: Positive (signal from sensor)
Black: Negative (signal from sensor)
Clear: Shield/Ground
What wire goes where? I see A0, A1, SDA, SCL, 5V, and ground.
I assume the clear/shield goes to ground, but where does the red and black wire go to?
TIA
The output is described as 0 - 350 mV (i.e. analogue) so you will probably need something like Werk's Solar Radiation Interface Kit (with Red to the input and black to the local ground).  That thread includes a link to the (long) main forum discussion.
Cheers,  Alan.
(15-09-2017, 10:39)danner Wrote:  I just snagged an Apogee SP-110 pyranometer off of ebay. I think I got a pretty good deal for it, but I guess the jury is still out until I get it connected and running. Big Grin
Congratulations!
The price is very good, but: "Shipping: May not ship to Czech Republic - ..."  Huh
So I'm out of luck.
Unfortunately only ships to USA. Sad
Werk tested mine and you will see reference to this in Allycats link above and wiring as described. Also see here:
http://www.meteocercal.info/forum/Thread...ght=Apogee
You will need interface kit;
http://www.meteocercal.info/forum/Thread...erface-Kit
I am sure you have this:
https://www.apogeeinstruments.com/conten...manual.pdf
(15-09-2017, 12:23)hornychz Wrote:  The price is very good, but: "Shipping: May not ship to Czech Republic - ..."  Huh
So I'm out of luck.
(15-09-2017, 12:24)JT118 Wrote:  Unfortunately only ships to USA. Sad
An American volunteer ... to send to Europe?
If purchasing several European (sharing of the shipping costs), I am starting.
An idea of weight for 1
Nice week end
I need another board to make this work with my transmit board?
(15-09-2017, 22:10)danner Wrote:  I need another board to make this work with my transmit board?
Yes, of course. As Alan said, you have to amplify the signal to the level needed for Arduino ...
Ok, thanks.
The answer to this question, is yes and no!
You can use your Apogee SP-110 pyranometer without the Solar / UV interface, connecting it directly to your TX board, the drawback of this approach is that you will get a very poor resolution and precision. The code is prepared for this possibility, but need edition on two lines.
If you want to try using it directly connected to the TX board, just let me know and I will tell you the required changes on the code.
(16-09-2017, 01:43)Werk_AG Wrote:  You can use your Apogee SP-110 pyranometer without the Solar / UV interface, connecting it directly to your TX board, the drawback of this approach is that you will get a very poor resolution and precision.
That's definitely not what I want so I need to order a Solar/UV interface board from you please.
I also want to eventually connect leaf wetness, and soil moisture, soil temperature, does that require another board?
Users browsing this thread: 7 Guest(s)
