Web server
I'm playing with Pro2 plus RX and Tx with Soil/Leaf interface.
OneWire connected to S1 and L1.
It's working on Rx dedicated screen:
But on web server S1 and L1 temp data are missing:
My config file:
// -------------------------------------------------------------------------------------- //  WeatherDuino Pro2 PLUS - Version: 2.00 b018 //     Start of user configurable options // -------------------------------------------------------------------------------------- // -------------------------------------------------------------------------------------- //   Define Name and ID's for this weather station // -------------------------------------------------------------------------------------- const char WeatherStation_Name[] = "MeteoMeyenheim"; #define Station_ID            0x1B    // Station_ID, use the same value in all TX units #define Relay_ID              0xB3    // Relay_ID,   use the same value in all WD units // -------------------------------------------------------------------------------------- //   Define your Weather Station location // -------------------------------------------------------------------------------------- #define LATITUDE      479    // Put here your Station latitude in tenths of degrees North #define LONGITUDE      73    // Put here your Station longitude in tenths of degrees (minus for West) #define ELEVATION     208    // Put here your Station height above sea level in Meters // -------------------------------------------------------------------------------------- //   Define rules for Auto Summer Time Display, and clock adjustment // -------------------------------------------------------------------------------------- // Example for Australia Eastern Time Zone (Sydney, Melbourne) // TimeChangeRule aEDT = {"AEDT", First, Sun, Oct, 2, 660};    //UTC + 11 hours // TimeChangeRule aEST = {"AEST", First, Sun, Apr, 3, 600};    //UTC + 10 hours // Timezone myTZ(aEDT, aEST); //TimeChangeRule PST = {"PST", Last, Sun, Mar, 1, 60};   //Portuguese Summer Time -  "UTC + 1" or GMT + 1 //TimeChangeRule GMT = {"GMT", Last, Sun, Oct, 2, 0};    //Portuguese Winter Time -  "UTC + 0" or GMT TimeChangeRule PST = {"PST", Last, Sun, Mar, 1, 120};   // Summer Time -  "UTC + 2" or GMT + 2 TimeChangeRule GMT = {"GMT", Last, Sun, Oct, 2, 60};    // Winter Time -  "UTC + 1" or GMT + 1 Timezone myTZ(PST, GMT); // -------------------------------------------------------------------------------------- //   Define Roll Over Hour for Meteorological Day // -------------------------------------------------------------------------------------- #define MeteoDay_HStart 0    // Use values from 0 to 23 // -------------------------------------------------------------------------------------- //   Define your Display type // -------------------------------------------------------------------------------------- #define DisplayType     3    // 1= LCD 20x4, 3= TFT 320x240 ILI9341 // -------------------------------------------------------------------------------------- //   Define Display Backlight TimeOut // -------------------------------------------------------------------------------------- const byte  BackLight_Timeout =  60;   // Timeout for display backlight in minutes (1 to 255). 0 = Always ON #define Use_ScreenSaver           1     // Instead of turn off TFT backlight show a big clock screen. 0= No, 1= Yes // -------------------------------------------------------------------------------------- //   Define data display units // -------------------------------------------------------------------------------------- #define Date_Time_Format 0     // 0 for dd-mm-yyyy, 1 for yyyy/mm/dd byte Temp_Display_Unit = 0;    // 0 for ºC, 1 for ºF byte ATM_Display_Unit  = 0;    // 0 for mBar, 1 for inHg byte Rain_Display_Unit = 0;    // no setting, always mm byte Wind_Display_Unit = 0;    // 0 for Km/h, 1 for mph, 2 for m/s, 3 for Knots // -------------------------------------------------------------------------------------- //   Define the type of your Barometric Pressure Sensor // -------------------------------------------------------------------------------------- #define Barometric_Sensor  0   // 0= BME280, 1= BMP280 2= BMP085 / BMP180 // -------------------------------------------------------------------------------------- //   Define the type of your inside Temperature / Humidity Sensor // -------------------------------------------------------------------------------------- #define InsideTH_Sensor  0   // 0= BME280, 1= HTU21D, 2= SHT21, 3= SHT31 // -------------------------------------------------------------------------------------- //   Fine adjusts for Inside Temperature and Barometer // -------------------------------------------------------------------------------------- const int   TemperaturaInt_offset =   0;   // Inside Temperature Fine Adjust in Tenths of Degree (-4 = -0,4ºC) const float pressure_offset       =   0;   // Pressure Fine Adjust in mB // -------------------------------------------------------------------------------------- //   Define the type of your outside Temperature / Humidity Sensor // -------------------------------------------------------------------------------------- #define MainOutTH_Sensor 0   // 0 for sensor type SHT31, SHT21 or HTU21D, 1 for sensor type SHT1x or DHT22 // -------------------------------------------------------------------------------------- //   Define Wind Speed and Wind Gust resolution // -------------------------------------------------------------------------------------- // This setting only have effect when the software is used in Davis VP emulation mode #define VP2_WindRes     2    // If set to 2, set Cumulus Wind Speed and Wind Gust multipliers to 0.448. Wind Resolution 0.72 Km/h                             // If set to 1, set Cumulus Wind Speed and Wind Gust multipliers to 0.224. Wind Resolution 0.36 Km/h                             // WARNING !!! Setting this variable to 1 allows a better wind speed and gust resolution,                             // but also limits both of them, to a maximum reading of just 91.8 Km/h                             // If set to 0, system uses Standard Davis wind resolution (1 mph or 0.1mph with LOOP2).                             // Weather Display users should set this option to 0 - Standard Davis wind resolution   // -------------------------------------------------------------------------------------- //   Define use of Wind Gust Spike prevention routines (mostly for FO anemometers) // -------------------------------------------------------------------------------------- #define WindSpikeControl 1   // 0= Disable, 1= Enable // -------------------------------------------------------------------------------------- //   Define the source of your main outside sensors // -------------------------------------------------------------------------------------- // ---- If you are using just one TX board, the source for all items should be equal to your single TX Unit ID (most likely zero). // ---- Define the source of your main Temperature / Humidity sensor #define TH_OutUnit       0   // 0= Temp/Hum sensor connected to TX_Unit 0, 1= Temp/Hum sensor connected to TX_Unit 1, ... // ---- Define the source of your Main Wind sensor #define WIND_OutUnit     0   // 0= Wind instruments connected to TX_Unit 0, 1= for TX_Unit 1, ... // ---- Define the source of your main Rain Gauge #define RAIN_OutUnit     0   // 0= Rain Gauge connected to TX_Unit 0, 1= for TX_Unit 1, 3 for Auriol RF Rain Gauge // ---- Define the source of your main Solar / UV sensores #define SRUV_OutUnit     9   // 0= Solar Rad / UV sensors connected to TX_Unit 0, 1= for TX_Unit1, 9 for not used // ---- Define type of Solar Radiation / UV Sensors // ---- Support for Solar Radiation sensor type 2 and UV sensor type 4 (it is a PAR sensor not a UV Sensor) still are experimental #define Solar_Sensor     1   // 0 not used, 1= Solar Cell "Pyranometer", 2= Apogee SP-110: Self-Powered Pyranometer #define UV_Sensor        1   // 0 not used, 1= UVM-30A, 2= Reserved, 3= Reserved, 4= Apogee SQ-110: Photosynthetically Active Radiation Sensor #define UV_Transmission 75   // UV Transmission percentage of UV sensor cover material // -------------------------------------------------------------------------------------- //   Extra Sensors Settings and Mapping // -------------------------------------------------------------------------------------- // ---- Define the source and sensor type (number) for each of the seven extra sensors, insert 9 if not used. //      Sensors SHT31, SHT21 or HTU21D are type 0, sensors SHT1x or DHT22 are type 1 // // ---- Source 0 means TX unit0, 1 means TX unit1... // ---- Source 6 (Reserved) // ---- Source 7 is for BIOS Sensor (Only Temperature is shown) // ---- Source 8 is for Air Quality Monitor. 0= Temperature/Humidity, 1= Dust Density/AQI // ---- (AQI sensors can be mapped to any position, but should be mapped in sequence, Temperature/Humidity always first) // // ---- First field = Sensor source, Second field = Sensor type (0 or 1 for TX units) // ---- Example: // ----                          ES0   ES1   ES2   ES3   ES4   ES5   ES6     //#define ExtraSensors_Source { {0,1},{1,1},{9,9},{6,3},{9,9},{8,0},{8,1} } //               {0,1} - First extra sensor (ES0), will be sensor 1 from TX unit0 //               {1,1} - Second extra sensor (ES1), will be sensor 1 from TX unit1 //               {9,9} - Third extra sensor (ES2), not used - not mapped //               {6,3} - Fourth extra sensor (ES3), will be OneWire sensor number 3 (OneWire sensors are numbered from 0 to 3) //               {9,9} - Fifth extra sensor (ES4), not use - not mapped //               {8,0} - Sixth extra sensor (ES5), will be Temperature / Humidity from the Air Quality Monitor //               {8,1} - Seventh extra sensor (ES6), will be Dust Density / AQI index from the Air Quality Monitor // //-----                        ES0   ES1   ES2   ES3   ES4   ES5   ES6     #define ExtraSensors_Source { {5,9},{5,9},{5,9},{5,9},{5,9},{0,1},{7,0} } // ---- Define personalized names for each Extra sensor. Attention, maximum 8 chars #define ExtraSensor1_Name "Cave" #define ExtraSensor2_Name "Cellier" #define ExtraSensor3_Name "Chambre" #define ExtraSensor4_Name "Schirla" #define ExtraSensor5_Name "Soute" #define ExtraSensor6_Name "SENSOR 5" #define ExtraSensor7_Name "Dust/AQI" #define DomoSensor1_Name "Domo1" #define DomoSensor2_Name "Domo2" #define DomoSensor3_Name "Domo3" #define DomoSensor4_Name "Domo4" #define DomoSensor5_Name "Domo5" #define DomoSensor6_Name "Domo6" #define DomoSensor7_Name "Domo7" // -------------------------------------------------------------------------------------- //   BIOS soil moisture sensor settings // -------------------------------------------------------------------------------------- // ---- Please use the included BIOS_ID_Scanner sketch to find you BIOS Device ID #define BiosSensor_ID 0   // Device ID in HEX format, or 0 not used // -------------------------------------------------------------------------------------- //   Soil / Leaf Interface Settings and Sensors Mapping //   (The mapping logic is the same than used with the Extra Sensors) // -------------------------------------------------------------------------------------- // 0 = Soil Leaf Interface not used // 1 = Soil Leaf Interface connected to a TX unit #define SoilLeaf_Interface  1   // 0, 1, // ---- For Soil & Leaf data from SoilLeaf_Interface wired to a TX unit, use TX Unit number as source // ---- For BIOS Soil Temp / Moisture use 7 as source // ---- To disable use 9 in both fields //                                 S1    S2    S3    S4 #define SoilTempSensors_Source  { {0,0},{9,9},{9,9},{9,9} } #define LeafTempSensors_Source  { {0,1},{9,9},{9,9},{9,9} } #define SoilMoistSensors_Source { {9,9},{9,9},{0,2},{9,9} } #define LeafWetSensors_Source   { {9,9},{9,9},{9,9},{0,3} } // ---- Define personalized names for each Soil and Leaf sensor. Attention, maximum 8 chars #define SoilSensor1_Name "S1" #define SoilSensor2_Name "S2" #define SoilSensor3_Name "S3" #define SoilSensor4_Name "S4" #define LeafSensor1_Name "L1" #define LeafSensor2_Name "L2" #define LeafSensor3_Name "L3" #define LeafSensor4_Name "L4" // Define VWC calculation method // Method 1 applies only for VH400 soil moisture sensor // // METHOD 1 - Conversion from voltage to VWC (volumetric water content) is done using the piecewise regressions provided by the manufacturer // at http://www.vegetronix.com/Products/VH400/VH400-Piecewise-Curve.phtml // // METHOD 2 - Used for any sensor which have a linear output between voltage and VWC (0V=0VWC, maxV=100VWC) . #define VWC_CalcMethod 1 // Max and Min output voltage of the analog sensors connected to Soil / Leaf Interface // Default value for Decagon Devices LWS Leaf Wetness Sensor (3.3V power): Max. Output Voltage - 1395mV (max wetness), Min Output Voltage - 530mV (dry) //                                                  ADC1  ADC2  ADC3  ADC4   const unsigned int AnalogSensor_MaxVoltOut[4]   = { 3000, 1395, 5000, 5000 };    // Values in miliVolts const unsigned int AnalogSensor_MinVoltOut[4]   = {    0,  530,    0,    0 }; // -------------------------------------------------------------------------------------- //   Broadacasting settings for Wireless Display Units // -------------------------------------------------------------------------------------- #define Relay_Data       1   // 0= Disables Data Relay, 1= Enables Data Relay // -------------------------------------------------------------------------------------- //   Davis compatible Data Logger Settings // -------------------------------------------------------------------------------------- #define Logger_Enable    1   // 0= Disable 1= Enable byte ARCHIVE_PERIOD  =   5;  // Default Archive Period in Minutes (Usable values: 1, 5, 10, 15, 30) // -------------------------------------------------------------------------------------- //   Easyweather format data Output // -------------------------------------------------------------------------------------- #define Easyweather_Out  0   // 0= Disable (defaut) 1= Enable // -------------------------------------------------------------------------------------- //   Internet Settings // -------------------------------------------------------------------------------------- #define Enable_Internet     1                       // 1= Enable Internet connection, 0= Disable //#define SSID        "----" //#define PASSWORD    "----" #define Enable_NTP          1                        // 1= Enable Sync time with NTP servers, 0= Disable // NTP Server: #define timeServer "time.nist.gov"                 // ntp1.nl.net NTP server //#define timeServer "80.96.196.58"                  // timp.mcsi.ro //#define timeServer "193.79.237.14"                 // ntp1.nl.net NTP server // Weather Wunderground Settings #define Enable_WUupload     0                        // 1= Enable upload to Wunderground,     0= Disable #define WUupload_period     6                        // Period in minutes between uploads to WU (avoid use less than 3 minutes) #define WUupload_InTemp     0                        // 1= Enable upload of Inside Temperature / Humidity, 0= Disable // ---- Wunderground Personal Data #define WUNDERGROUND_STATION_ID "----"               // Weather Underground station ID #define WUNDERGROUND_PWD        "----"               // Weather Underground password // Web Server Settings #define Enable_WebServer    1                        // 1= Enable 0= Disable #define WebServer_port     80                        // WebServer port (default 80) #define Enable_DomoData     1 // -------------------------------------------------------------------------------------- //   Enable / Disable GPIO routines - General Purpose Input / Output ports // -------------------------------------------------------------------------------------- #define UseGPIO  0   // 0=Disable, 1= Enable // -------------------------------------------------------------------------------------- //   Test Mode : Never run a live system in test mode // -------------------------------------------------------------------------------------- #define TestMode    false    // false= Normal working mode, true= Test mode only (no logger, no usb connection) // -------------------------------------------------------------------------------------- //   Hardware settings // -------------------------------------------------------------------------------------- // ---- Define LCD I2C address // Only change this if your LCD don't display any data. I2C_Scanner utility may help you to find the address of your LCD display // Default address will work most of the times! #define LCD_I2C_Address 0x27   // -------------------------------------------------------------------------------------- //   SHT31 I2C Address - Default address will work most of the times! // -------------------------------------------------------------------------------------- #define SHT31_address 0x44       // Default value is 0x44, but it can be changed to 0x45 // -------------------------------------------------------------------------------------- //   Presure Sensor Address (no need to change) // -------------------------------------------------------------------------------------- //#define BMP085_ADDRESS 0x77    // I2C address of BMP085 or BMP180 // -------------------------------------------------------------------------------------- //   Debug helper // -------------------------------------------------------------------------------------- //#define PRINT_DEBUG_NTP_UPDATE    // Prints to serial monitor messages related to sync time with NTP server //#define PRINT_DEBUG_WU_UPLOAD     // Prints to serial monitor messages related to Weather Underground upload. //#define PRINT_DEBUG_TCP_SERVER //#define PRINT_DEBUG_AURIOL //#define PRINT_DEBUG_BIOS // --------------------------------------------------------------------------------------------------- //     End of user configurable options // ---------------------------------------------------------------------------------------------------
Did i miss something in the config ?
I think it should perhaps be because i only define TempSensors (Soil/Leaf) and NO SoilMoist or LeafWet sensors !
Laurent
The solution :
In NET.ino line ~361 changed the test conditions (same as in D_TFT.ino line~341)
line ~361
 Content += "<br><table cellpadding=\"10\"><tr><td width=\"290\" valign=top bgcolor=\"#DBB05B\">";  Content += "<b>SOIL</b><br>";  for (byte i=0; i<4; i++)   {     if ((SoilTemp_Source [i][0] != 9) || (SoilMoist_Source[i][0] != 9))      {         Content += "<br>";         Content += SoilSensName[i];         Content += " - Temp: ";             Content += Soil_Data[i][0] / 10.0;         Content += "C | vmc: ";         Content += Soil_Data[i][1];      }   }  Content += "<br><br><b>LEAF</b><br>";  for (byte i=0; i<4; i++)   {     if ((LeafTemp_Source [i][0] != 9) || (LeafWet_Source[i][0] != 9))      {         Content += "<br>";         Content += LeafSensName[i];         Content += " - Temp: ";             Content += Leaf_Data[i][0] / 10.0;         Content += "C | Wetness: ";         Content += Leaf_Data[i][1];         Content += "%";              }       }
Perhaps there  some more code to add  to mask the unused values Rolleyes
(05-04-2017, 21:59)laulau Wrote:  The solution :
line ~361
Hi Laulau
Be aware that you are pointing users to code supposedly existing in some line numbers, that only exist in your own modified WeatherDuino Pro2 software, the lines could be (and are) different on the official WeatherDuino Pro2 software. At least do it referring to lines numbers of the official WeatherDuino Pro2 PLUS software. Surely it will avoid confusion an troubles to users.
Regarding to this, the WeatherDuino Pro2 software is released under GNU GPLv3, so, you and everyone can redistribute it and/or modify it, but only under the terms of the GNU General Public License as published. Next time you publish a modified version of the whole WeatherDuino Pro2 PLUS software package, please try to follow the terms of the licence.
(05-04-2017, 21:07)laulau Wrote:  Did i miss something in the config ?
Yes it is. Your config is fine.
I took note of the suggested changes, and after analysing any implications, I will consider introducing on next software release, the required changes on the code to allow showing the data of Soil Temperature sensors when they are not paired with a Soil Moisture sensor.
However keep in mind that despite the flexibility of the sensors mapping scheme, it was designed to work with a pair of Soil Temp sensor and Soil Moisture sensor with the same order number. So, some combinations will not work (and they should not work!).
(06-04-2017, 03:04)Werk_AG Wrote:  Hi Laulau
Confused Confused Confused
It is not easy to understand exactly all the terms of the license.
If I understood correctly I should have provided the libraries with the code as well as the file LICENSE.txt ?
Maybe is it more reasonable to share modified code only to interested people via PM?
I apologize, I'm really sorry.
Laurent
No problem Laurent, I'm not upset with that, just calling your attention to that matter.
It is just a matter of changing the author of the code to yourself. Making a reference to the original code is a nice action too. Very simple!
GNU GPLv3 license, is one of licenses which gives more freedom to code modifications.
However, publishing modified software packages here, may not be a good idea, because at some point this may introduce confusion to users and visitors, as there are no support or info for the modified code. Doing it in your own website is fine.
