OK so out of curiosity I had a look at what other Arduino compatible boards (i.e. cheap ones) there are, and came up with ;-
1) Arduino Yun ;-
http://www.ebay.co.uk/itm/Arduino-Yun-Wi...259a30f4aa
It's the most expensive, at 41 GBP (65 USD), it uses an Atmel Atmega32U4 @ 16MHz, an 8-bit RISC microcontroller with 32KBytes of Flash memory, but with a Atheros AR9331 @ 400 MHz, 68.6 mm × 53.3 mm (2.7 in × 2.1 in), with USB and 5V. What I find interesting is the mention of the 16 MBytes of Flash and the 64 MBytes of SRAM, but I suspect that both of the latter memories are only available by the "Wifi system on a chip (SoC) [Atheros] running Linino, a MIPS GNU/Linux based on OpenWrt.", and thus not accessable directly for user programs?
2) is more interesting because it's rather cheaper at 27 GBP (43 USD) ;-
http://www.ebay.co.uk/itm/New-SainSmart-...461050fdb4
...it's based on the Atmel ATmega2560 @ 16 MHz, 101.6 mm × 53.3 mm (4 in × 2.1 in), 5 V, and has 256K of Flash (most of it is available for user programs), it is an 8-bit RISC microcontroller. However I think it's still too expensive.
3) is the (again much cheaper at 15 GBP) Arduino Due ;-
http://www.ebay.co.uk/itm/New-Due-R3-Boa...417f76c8b7
...and is interesting as it's the first Arduino board based on an ARM Processor, ATSAM3X8E (Cortex-M3) , a 32-bit RISC microcontroller @ 84 MHz, 101.6 mm × 53.3 mm (4 in × 2.1 in), USB, 3.3 V, features 2 channel 12-bit DAC, 512KB Flash memory (for user programs?) and 96KB SRAM. Unlike most arduino boards, it operates on 3.3 V and is not 5 V tolerant. I feel that the cost of this is just about bearable but a little expensive for my liking.
4) the final option in the Arduino line up is the Mega 2560, which is basically the same board as the above Mega ADK as far as I can tell, still @ 16MHz and still has 256K Flash but a lot cheaper at 6GBP ;-
http://www.ebay.co.uk/itm/Chic-Mega-2560...43d2a368f0
I found my info at
http://en.wikipedia.org/wiki/List_of_Ard...le_systems .
It would seem then that option #4 would be the "ideal" board to migrate to for the next version of WeatherDuino. If I was doing the programming anyway LOL. Unfortunately I am only the most basic of programmers LOL. Seriously Werk_AG, I am sure you have had similar thoughts, and I'll leave it in your capable hands, but it would be nice to see new features (soil moisture sensing, fog sensing etc) being made possible by having 8x the amount of available memory than the Nano!!
BTW my friend in SE England just sent me (it's still in the post at the moment, I can expect it in 2 days' time apparently) the Davis VP1 plus (dead, needs a new transmitter board I am guessing since there have been no flashes from the green LED that is (I think) supposed to be on the TX board), I'll have a look at it for him but I have the feeling it will be beyond my abilities to fix it. And there are no spares available anywhere. And the cost of a replacement board would be outrageous anyway IMHO (I've seen them on Ebay for the VP2 and they are over 100 GBP!).
Best Regards,
Alistair G.
www.wunderground.com/personal-weather-station/dashboard?ID=IENGLAND609
Fine Offset WH-1081 (Maplin N96FY) at present, soon to be WDPro2 I hope so that I can have Solar & UV graphs as well
