Hi Guys,
I'm building up my Weather Station. At this stage I have built my TX (3.11) and RX (5.02) with 20x4 LCD screen. At this stage I only have temp/humidity and baro sensors connected. TX and RX appear to be working ok and are communicating fine, and I can see "In" and "Out" temps and humidity on the RX display..
I've assembled the wireless display and conected to a 2.8" TFT touch screen. The screen initializes ok and paints the main page ok. After about 4 mins, I get message "not receiving data". I "don't" see any blinking LED on the wireless display..????
The WD address in both the RX unit and the WD is default 0xA3. In the RX I have a 1 in the option to relay data to WD. I see the blinking TX led on the RX working.
At this stage I'm really not sure where to go next and how to debug this issue. Any suggestions or comments would be greatly appreciated and openly received.
Hope that together we can work though this and get this WD operational. In advance, thanks guys. Look forward to you comments.
Mark R
I moved the WD away from the RX unit, approx 1.5 meters. Did a couple of resets, and on one occasion I did see "In" and "Out" temps and humidity on the WD TFT display. But once only. I haven't been able to repeat this. Note, I do not have any temp sensor connected to the WDisplay.
Thanks guys.
Mark R
I temporarily moved the WDisplay out to another room, approx 10m away, and still no data on the WD screen. So I don't think its a proximity issue and the TX swamping the RX in the WDisplay.
Mark R
What should the LED do on a working WirelessDisplay..??? Should it blink as it receives data..???
Mark R
I connected a CRO to the Antenna Output on the TX (sensor sender) unit, and captured a signal with the camera on my phone (not a capture cro
). I then connected the CRO to the Antenna output on the TX module of the RX unit, and captured similar signal.
Not sure how to attached photos to this post, in this forum..???? Is it possible somehow..???
So, on the surface, it looks like the TX module on my WeatherDuino RX unit working and sending a signal out, to the WirelessDisplay.
I'm using those little 80mm 433Mhz antennas, from eBay, that have the right-angle bend just after the connector.
Mark R
Thanks guys.
Mark R
Mark R
Mark R
). I then connected the CRO to the Antenna output on the TX module of the RX unit, and captured similar signal. Not sure how to attached photos to this post, in this forum..???? Is it possible somehow..???
