24-08-2014, 02:34
Quote:You already used this "Stevenson Screen" with your previous weather station, or it was "developed" now for the WeatherDuino Pro2?
It was used on the old WS3081 as well. Though I had to change the mounting for the sensor mast as the gutter wasn't on the roof previously.
Quote:Are you using WeatherDuino Pro2 to control the fan? I suppose so.
Surely you noticed that in the TX unit software, you can change the on / off parameters for the fan. Perhaps you have to change default values, they may not be appropriate for your location / instalation.
I believe default outside temperature value for turning the fan on, may be too high.
I saw the settings in the TX firmware for the fan, but I'm currently just running the fan off the output of the 7809 regulator. Really the only times I'd need the fan not running is when the sun isn't shinning. Maybe there's an idea for the now unused solar sensor off the WS3081
Anyway the "Stevenson Screen" seems to work fairly well as now my station appears to follow the other stations in my area quite well.
http://www.wunderground.com/personal-wea...D4#history
![[Image: RX_3.png~original]](http://i227.photobucket.com/albums/dd235/unclebob420/RX_3.png~original)
![[Image: RX_1.png~original]](http://i227.photobucket.com/albums/dd235/unclebob420/RX_1.png~original)
![[Image: RX_2.png~original]](http://i227.photobucket.com/albums/dd235/unclebob420/RX_2.png~original)
