Threads: 2
"If you have replaced the RTC, don't forget to do a complete system initialization." - did that,initially nbg, but about 3 or 4 hours later the !@#$ thing came good, data bursts everywhere, outside info, outside battery, all good ! Haven't touched it ! USB connection still locks the thing up - local rf problem ? Starting to think of taking up lawn bowls instead..............! Could it be just a bad rf link, too much noise, other 433 signals ? Can't see it on spec. an. though, and rf sounds clean.....?
Threads: 333
Forget the RF part... the system does not freeze because is receiving or not RF signals. Concentrate in the USB connection.
There is a thing I can't understand: if the system freeze as soon as you connect the USB cable, how you are able to program it?
Do you close the VP1 switch after programing the unit?
Could you try it in a different PC, in a different location?
Threads: 2
the program seems to upload without a problem, I close VP1 after I get the "upload finished" message. have tried it on a laptop running XP - same problem. I have replaced a few bits since then so I'll repeat the tests again, and in diff. locations.
At the moment, without a usb cord plugged in, it's running perfectly !!
Threads: 9
Weather Station: Darra Weather
26-07-2015, 12:25
(This post was last modified: 26-07-2015, 12:31 by
qldbureau.)
Spent a long day troubleshooting.
1. Reinitialized the RTC. Froze. Disassembled the whole Rx set outside of the metal case and ran it 'naked' on the bench. Froze just after restart.
2. Connect to another computer with Windows 7 - also froze.
3. Discovered that it also froze with no USB cable connected.
4. Remelted and applied more solder to major components.
5. Swapped nano boards and reprogrammed between Tx & Rx unit - still freezing.
6. Replaced RTC module and initialized. Now the RTC EEPROM is listed on I2C memory scanner! Original RTC must have been faulty. Froze when reconnecting USB only.
7. Applied more solder around logger chip.
8. Not freezing now when only connected to 12 volt. Logger is working in this mode. Changed archive to 1 minute so I did not have to wait so long for testing.
9. Occasional freeze when reconnecting USB. Seems ok once restarted and stabilized. Tested several times disconnecting Cumulus and USB, but leaving 12 volts applied. Each reconnect of USB and Cumulus restarts downloaded several fresh archives. Reassembled into box.
So waiting for new USB cable. I think I am about to order an FTDI board.
This is now my full I2C scan result since replacing the RTC:
Scanning...
I2C device found at address 0x27 !
I2C device found at address 0x57 !
I2C device found at address 0x68 !
I2C device found at address 0x77 !
done
Threads: 2
I've noticed that if I o/c the + and -, and the shield, inthe usb cable, the problem still happens, ie., thing still freezes - not usb power related..........?
