Threads: 31
Weather Station: Conder Weather, Canberra
It must be related to my PC or driver then. I'll try it on my server some time this weekend.
Threads: 336
It's good to know that there is at least one more solution.
Did not know this one, with capacitor and resistor. The one I tested and did not work, was only with the capacitor.
Tonight I will try this solution.
Did you ever try replacing the 120R resistor, by one of around 112R?
Threads: 336
Hi, uncle_bob
So far we have talked a lot of hardware and software, but now we get to the main point of all this: Measuring atmospheric data
I am very happy with these pictures and once again a big thank you for the dedication and time expended to get these comparative graphics.
As with any weather station, the accuracy of the data depends mainly on the quality of the measuring instruments used. From my experience, the DHT22 is pretty good in temperature measurement, a little less in moisture.
If you have more comparative data, I would like to see them.
The lines on the graph are quite soft which indicates to me that the transmission system is also working well.
