28-04-2015, 05:51
Quote:The easiest option to do so is to sign up on the Weather underground then punch in the details in Cumulus. Give me a shout if you get stuck.Thanks. Too easy!
Up and reporting ID INEWSOUT617. Gladesville NSW
It's a bit too much to go into detail here.
(28-04-2015, 05:51)moolight0551 Wrote:Quote:The easiest option to do so is to sign up on the Weather underground then punch in the details in Cumulus. Give me a shout if you get stuck.Thanks. Too easy!Up and reporting ID INEWSOUT617. Gladesville NSW
(02-05-2015, 04:55)Werk_AG Wrote:Sure I will do that. Also have a website happening too!(28-04-2015, 05:51)moolight0551 Wrote:Quote:The easiest option to do so is to sign up on the Weather underground then punch in the details in Cumulus. Give me a shout if you get stuck.Thanks. Too easy!Up and reporting ID INEWSOUT617. Gladesville NSW
Congratulations! Your weather station is up and running.
Your data are comparing very well with an nearby weather station from a reputed brand.
If you are proud of your weather station, maybe you could add in your wunderground profile, under hardware, the name WeatherDuino Pro2
(03-05-2015, 13:47)moolight0551 Wrote: An excellent project all round. Thanks to all. I notice Part 3 of the Silicon Chip article has been published. You and Uncle_Bob deserve many many beers.
(21-08-2015, 04:48)Werk_AG Wrote: Hi,Hi Caneira,
A change from 0.3mm to 0.8mm it's a very big change, but if you really want to do it, I can help you. Currently this can't be done only in the TX software.
Can you please tell me the software version and build, that you are using in your TX and RX units?
Sorry for asking, are you using an FO rain gauge?
