31-12-2023, 06:11
(This post was last modified: 31-12-2023, 06:29 by Palmyweather.)
This is becoming quite the mystery.
I have attempted again today to get the DHT22 sensors to work including downloading from this forum the software again and ensuring my libraries match.
I have tried 3 different configuration files over two different TX boards which gives me the same results. These are titled:
Main TX:
Ground TX:
Freshly downloaded from the forum configuration:
For reference, I have tested this sensor using TX software build v7.0_b002 on my main board code and existing configuration with the same outcome.
- Main TX board - my main transmitter unit with wind, rain, UV attached.
- Ground TX board - secondary transmitter with ground and temperature.
- Test configuration - This was a fresh copy of the code downloaded once I started having issues in case any other configuration settings were conflicting.
Main TX:
// WeatherDuino Pro2 Universal TX AT328 - Version: 7.0_b002
// Start of user configurable options
// Define ID and TX unit number
#define Station_ID 0xA1 // Must be equal to your RX Unit (Value from 0x00 to 0xFF)
#define Unit_ID 0 // If you use only one TX unit define it as Unit_ID = 0
// For a second TX unit, define it as Unit_ID = 1
// Define type of Temperature / Humidity sensor used as Sensor 0 and / or Sensor 1
#define TH_SENSOR0 9 // [SENSOR 0] - 0 for SHT2x sensor, 1 for SHT31 sensor, 2 for HTU21 sensor, 9 for Not Used
#define TH_SENSOR1 1 // [SENSOR 1] - 0 for SHT1x sensor, 1 for DHT22 sensor, 9 for Not Used
// Define which Temp / Hum sensor controls the fan, and threshold values
#define FANCONTROL_SENSOR 1 // 0 for Sensor 0, 1 for Sensor 1 (which sensor is used to control the RS Fan)
const int fanOn_HiTemp = 25; // RS Fan turn on when outside temperature is >= than this value (ºC)
const int fanOn_LowTemp = 2; // RS Fan turn on when outside temperature is <= than this value (ºC)
const int fanOn_LowWind = 1; // RS Fan turn on when Wind Average is <= than this value (m/s)
// Define type of Wind Speed sensor. See below for allowed types
--- Fine Offset Anemometers ---
Use 1O for standard FO anemometers
Use 11 for FO anemometer modified with 1 hall effect sensor
--- Inspeed Anemometers ---
Use 20 for Inspeed Vortex, digital 8 pulse revolution anemometer
Use 21 for Inspeed Vortex, hall efect sensor
Use 22 for Inspeed Vortex, read switch sensor
--- Davis Anemometers ---
Use 30 for Davis 6410, 7911 anemometer
--- Novalynx Anemometers ---
Use 40 for Novalynx, model 200-WS-02F
--- Environmental Measurements Limited ---
Use 50 for EML, model WSD1
--- Didcot Instrument Company ---
Use 60 for DIDCOT, model DWR205
--- Vector Instruments ---
Use 70 for Vector Instruments model A100LK
Use 71 for Vector Instruments model A100L2
Use 72 for Vector Instruments model A100R
#define WINDSPEED_SENSORTYPE 10 // SEE INFO ABOVE!!!
// Define type of Wind Direction sensor
--- Fine Offset Wind Vane ---
Use 1O for standard FO wind vane
--- Analogue Wind Vanes ---
Use 20 for any 5V analogue wind vane. See bellow for a list of tested models
- Inspeed E-Vane 2
- Davis 6410
- Novalynx, model 200-WS-02F
- Environmental Measurements Limited, model model WSD1
- DIDCOT, model DWD205
- Almost all 5V analogue wind vanes will work
#define WINDDIR_SENSORTYPE 10 // SEE INFO ABOVE!!!
// Analogue Vane Offset Calibration
const int WDir_offs = 0; // Usually there is no need to change default value (zero)
// Define Rain Gauge tip boucket value (mm)
Use 0.280 for standard FineOfset rain gauges (Datasheet value = 0.2794)
Use 0.200 for standard metric Davis rain gauges
Use 0.254 for standard imperial Davis rain gauges
#define COLLECTOR_TYPE 0.280 // Please note: Values must be in metric units. Max. resolution: 3 decimal digits
// Define type of UV Sensor
#define UV_SENSOR 0 // 0= UVM-30A, 1= VEML6075, 9= Not used
// Soil / Leaf Interface Enable Disable
#define SOILLEAF_INTERFACE 0 // 0 = Soil Leaf Interface not used, 1 = Enable Soil Leaf Interface
const byte Number_AnalogSensors = 2; // Up to 4 analog sensors
// Define which data this unit will send. 0 = Not send this data, 1= Send this data
#define ID0 1 // Temp/Hum Data
#define ID1 0 // Not Used
#define ID2 1 // Wind data
#define ID3 1 // Rain data
#define ID4 1 // SolRad / UV data
#define ID5 1 // Hardware Status - System Temp, Battery Voltage etc
#define ID7 0 // Send Soil & Leaf Temperature Data
#define ID9 0 // Send Soil & Leaf Moisture / Wetness Data
// VBat voltage fine tune (values in Volt, positive or negative)
#define VBAT_OFFSET 0 // Ex: 0.1 or -0.2
// Hardware Settings
// Define if the TMP36 sensor is instaled
#define USE_TMP36 1 // 0= Not Instaled, 1= Intalled
// SHT31 I2C Address - Default address will work most of the times!
#define SHT31_ADDRESS 0x44 // Default value is 0x44, but it can be changed to 0x45
// Debug
#define ENABLE_DEBUG
#define DEBUG_ID0
//#define DEBUG_ID2
//#define DEBUG_ID3
//#define DEBUG_ID4
//#define DEBUG_ID5
//#define DEBUG_SLINTERFACE
//#define EASYWEATHER_TEST
// End of user configurable options
// ---------------------------------------------------------------------------------------------------Ground TX:
#define Unit_ID 1 // If you use only one TX unit define it as Unit_ID = 0
const int fanOn_HiTemp = 26; // RS Fan turn on when outside temperature is >= than this value (ºC)
- Inspeed E-Vane 2
- Davis 6410
#define UV_SENSOR 9 // 0= UVM-30A, 1= VEML6075, 9= Not used
#define SOILLEAF_INTERFACE 1 // 0 = Soil Leaf Interface not used, 1 = Enable Soil Leaf Interface
const byte Number_AnalogSensors = 4; // Up to 4 analog sensors
#define ID2 0 // Wind data
#define ID3 0 // Rain data
#define ID4 0 // SolRad / UV data
#define ID7 1 // Send Soil & Leaf Temperature Data
#define ID9 1 // Send Soil & Leaf Moisture / Wetness Data
#define VBAT_OFFSET 0.8 // Ex: 0.1 or -0.2
// Debug
#define DEBUG_ID0
//#define DEBUG_ID2
//#define DEBUG_ID3
//#define DEBUG_ID4
//#define DEBUG_ID5
// ---------------------------------------------------------------------------------------------------Freshly downloaded from the forum configuration:
// WeatherDuino Pro2 Universal TX AT328 - Version: 7.0_b003
// Define which Temp / Hum sensor controls the RS fan, and threshold values
#define FANCONTROL_SENSOR 0 // 0 for Sensor 0, 1 for Sensor 1 (which sensor is used to control the RS Fan)
const int fanOn_HiTemp = 19; // RS Fan turn on when outside temperature is >= than this value (ºC)
- Inspeed E-Vane 2
- Davis 6410
#define VBAT_OFFSET 0.0 //
#define USE_TMP36 0 // 0= Not Instaled, 1= Intalled
// Debug
#define DEBUG_ID0
//#define DEBUG_ID2
//#define DEBUG_ID3
//#define DEBUG_ID4
//#define DEBUG_ID5
// ---------------------------------------------------------------------------------------------------For reference, I have tested this sensor using TX software build v7.0_b002 on my main board code and existing configuration with the same outcome.
