13-01-2023, 00:13
Hello coupe pete,
You are right, the KXD10036 module somehow disappeared completely...
But the one you found on eBay has a power of "only" 15 dBm, I recommend using the H34C 433 MHz module. It should have a power of more than 25 dBm.
(Better range.)
I also remembered that you probably wrote somewhere that the TX LED doesn't blink either. This could indicate a faulty switching MOSFET T1 2N7000.
Good luck!
(12-01-2023, 02:36)coupe pete Wrote: Just wondering how to find the correct TX module.
The parts list i found says it should be a KXD-10036 RF Transmitter Module 433MHZ which is what i currently have and seems impossible to find.
I found a thread by Werk which references a different type of part ? link shown below :-
433Mhz Wireless Transmitter ASK DC 3-12V Perfect for Arduino/ARM/AVR | eBay
Is either fine or do i need an exact replacement for what I have ?
(Better range.)
Good luck!
