Threads: 9
Weather Station: Darra Weather
Welcome Mick! Yes send a PM to Werk_AG to order your boards.
Usually I prefer ABS plastic cases. They are more easy to cut and make holes.
Take some pictures at the end, this could give some ideas to us.
Threads: 9
I tackled the logger chip this morning. When I run the I2C scanner test I get the following:
Scanning...
I2C device found at address 0x68 !
I2C device found at address 0x77 !
done
Are there supposed to be four lines reported back, or is this perfect?
You get this everytime you run I2C Scanner?
It lacks the addresses of the LCD and RTC eeprom.
Threads: 9
In the meantime I reheat solder on the pads, and now up to 3.
Scanning...
I2C device found at address 0x27 !
done
Still working on the missing one.
The missing one is important for the logger to work.
Strange, the RTC is detected, but the eeprom (located on the same module) is not.
As stated on the parts list, R5 and R6 should not be installed. Please check it too.
