07-12-2020, 23:01
I am trying to update my WD but get the following error when trying to upload the SPIFFS
Arduino: 1.8.13 (Windows 10), Board: "LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
[SPIFFS] data : C:\Users\JBA\Downloads\WeatherDuino_4PESP8266_WD_v7.1_b002_20201120 (1)\software\WeatherDuino_4PESP8266_WD_v7.1_b002\data
[SPIFFS] size : 2024
[SPIFFS] page : 256
[SPIFFS] block : 8192
/fonts/ArialBold11.vlw
/fonts/ArialBold11LEA.vlw
/fonts/NotoSansBold14.vlw
/fonts/NotoSansBold14LEA.vlw
/icons/home.bmp
/icons/home1.bmp
/icons/moisture.bmp
/icons/termo.bmp
/icons/tree.bmp
/icons/tree1.bmp
/icons/WDicon.bmp
/icons/wind.bmp
/ow_icons/clearday.bmp
/ow_icons/clearnight.bmp
/ow_icons/fewcloudsday.bmp
/ow_icons/fewcloudsnight.bmp
/ow_icons/mistday.bmp
/ow_icons/mistnight.bmp
/ow_icons/na.bmp
/ow_icons/rainday.bmp
/ow_icons/rainnight.bmp
/ow_icons/scatteredclouds.bmp
/ow_icons/showers.bmp
/ow_icons/snow.bmp
/ow_icons/thunderstorm.bmp
/splash/WDlogo.jpg
[SPIFFS] upload : C:\Users\JBA\AppData\Local\Temp\arduino_build_850739/WeatherDuino_4PESP8266_WD_v7.1_b002.spiffs.bin
[SPIFFS] address : 0x200000
[SPIFFS] reset : --before default_reset --after hard_reset
[SPIFFS] port : COM4
[SPIFFS] speed : 921600
[SPIFFS] python : python.exe
[SPIFFS] uploader : C:\Users\JBA\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\tools\upload.py
usage: esptool [-h] [--chip {auto,esp8266,esp32}] [--port PORT] [--baud BAUD]
[--before {default_reset,no_reset,no_reset_no_sync}]
[--after {hard_reset,soft_reset,no_reset}] [--no-stub]
[--trace] [--override-vddsdio [{1.8V,1.9V,OFF}]]
{load_ram,dump_mem,read_mem,write_mem,write_flash,run,image_info,make_image,elf2image,read_mac,chip_id,flash_id,read_flash_status,write_flash_status,read_flash,verify_flash,erase_flash,erase_region,version}
esptool: error: unrecognized arguments: --end
SPIFFS Upload failed!
