WD SPISSF upload - Printable Version
+--- Thread: WD SPISSF upload (/thread-1923.html)
WD SPISSF upload - Barrow4491 - 07-12-2020
I am trying to update my WD but get the following error when trying to upload the SPIFFS
  Arduino: 1.8.13 (Windows 10), Board: "LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600" [SPIFFS] data    : C:\Users\JBA\Downloads\WeatherDuino_4PESP8266_WD_v7.1_b002_20201120 (1)\software\WeatherDuino_4PESP8266_WD_v7.1_b002\data [SPIFFS] size    : 2024 [SPIFFS] page    : 256 [SPIFFS] block   : 8192 /fonts/ArialBold11.vlw /fonts/ArialBold11LEA.vlw /fonts/NotoSansBold14.vlw /fonts/NotoSansBold14LEA.vlw /icons/home.bmp /icons/home1.bmp /icons/moisture.bmp /icons/termo.bmp /icons/tree.bmp /icons/tree1.bmp /icons/WDicon.bmp /icons/wind.bmp /ow_icons/clearday.bmp /ow_icons/clearnight.bmp /ow_icons/fewcloudsday.bmp /ow_icons/fewcloudsnight.bmp /ow_icons/mistday.bmp /ow_icons/mistnight.bmp /ow_icons/na.bmp /ow_icons/rainday.bmp /ow_icons/rainnight.bmp /ow_icons/scatteredclouds.bmp /ow_icons/showers.bmp /ow_icons/snow.bmp /ow_icons/thunderstorm.bmp /splash/WDlogo.jpg [SPIFFS] upload  : C:\Users\JBA\AppData\Local\Temp\arduino_build_850739/WeatherDuino_4PESP8266_WD_v7.1_b002.spiffs.bin [SPIFFS] address  : 0x200000 [SPIFFS] reset    : --before default_reset --after hard_reset [SPIFFS] port     : COM4 [SPIFFS] speed    : 921600 [SPIFFS] python   : python.exe [SPIFFS] uploader : C:\Users\JBA\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\tools\upload.py usage: esptool [-h] [--chip {auto,esp8266,esp32}] [--port PORT] [--baud BAUD]                [--before {default_reset,no_reset,no_reset_no_sync}]                [--after {hard_reset,soft_reset,no_reset}] [--no-stub]                [--trace] [--override-vddsdio [{1.8V,1.9V,OFF}]]                {load_ram,dump_mem,read_mem,write_mem,write_flash,run,image_info,make_image,elf2image,read_mac,chip_id,flash_id,read_flash_status,write_flash_status,read_flash,verify_flash,erase_flash,erase_region,version}                ... esptool: error: unrecognized arguments: --end SPIFFS Upload failed!
RE: WD SPISSF upload - werk_ag - 08-12-2020
Hi Jim,
Try upgrade your ESP8266 board manager to latest version (2.7.4), then copy (or update) the "tools" folder included on the software package to: "Documents/Arduino".
Let me know if you need further help
RE: WD SPISSF upload - Barrow4491 - 08-12-2020
(08-12-2020, 04:05)Werk_AG Wrote:  Hi Jim,
All good now, Werk, thanks again
