19-06-2020, 13:15
Another one from me! The Pro2 compact won't connect to wifi despite the correct network name and password in the Credentials.h. Anything else I can do to fix this?
(19-06-2020, 13:15)sarahdal Wrote: Another one from me! The Pro2 compact won't connect to wifi despite the correct network name and password in the Credentials.h. Anything else I can do to fix this?
(19-06-2020, 14:51)Werk_AG Wrote:(19-06-2020, 13:15)sarahdal Wrote: Another one from me! The Pro2 compact won't connect to wifi despite the correct network name and password in the Credentials.h. Anything else I can do to fix this?
First thing to check is if the network name and password don't include special chars like "_", "&" or "%" etc.
(19-06-2020, 18:33)sarahdal Wrote: yes, it's just letters, and the password is all numbers
// WiFi Credentials
const char* WIFI_SSID = "StationID";
const char* WIFI_PASSWORD = "1234567890";(19-06-2020, 20:11)Werk_AG Wrote:Code:/ -------------------------------------------------------------------------------------- // WiFi Credentials // -------------------------------------------------------------------------------------- const char* WIFI_SSID = "StationID"; const char* WIFI_PASSWORD = "1234567890";
Maybe the ESP8266 is having a problem with connection with your router. Check your router encryption mode, WPA2/PSK should work (2.4GHz band)
Enabling debug mode may help.
Alternatively, can you try with another router?
(19-06-2020, 21:16)sarahdal Wrote: The password and ssid are in quotes, but I'm on "last mile" internet which means it's a connection shared with a couple hundred other people; usually it's not a problem if you don't need your own unique IP but it does mean I have zero access to my router. I'll speak to the guy who runs it - but argh, unless there's a way to run it off an ethernet shield
(19-06-2020, 22:29)Werk_AG Wrote: Does it mean you don't have a local WiFi network (LAN) at your home? There isn't any device which acts as an WiFi access point at home?
If you have a portable computer how do you connect it to Internet using WiFi? I'm just trying to understand what type of LAN you have.
Not having any kind of router at home, is new to me.
// Debug helper - Print debug messages to serial monitor. For testing purposes ONLY.
// !!! NEVER LEAVE ANY OF THESE DEBUG FUNCTIONS ACTIVE WHEN THE STATION IS CONNECTED BY USB TO ANY WEATHER SOFTWARE !!!
#define PRINT_DEBUG_WIFI(20-06-2020, 22:11)Werk_AG Wrote: For your complete peace of mind, I would like to start saying that if we conclude that Your Pro2 Compact receiver is damaged, I will repair it at no cost for you.
However, since all units are tested and programed before sent, and considering that its not easy create a damage on one unit, before send it back to me, I would like to ask you, to do some procedures:
1- On Config_Options.h enable the debug WiFi option, by uncommenting the first line. See below
Code:// -------------------------------------------------------------------------------------- // Debug helper - Print debug messages to serial monitor. For testing purposes ONLY. // // !!! NEVER LEAVE ANY OF THESE DEBUG FUNCTIONS ACTIVE WHEN THE STATION IS CONNECTED BY USB TO ANY WEATHER SOFTWARE !!! // -------------------------------------------------------------------------------------- #define PRINT_DEBUG_WIFI
then open the Arduino IDE serial monitor (set it to 19200 baud), compile the code and reprogram the device using the USB connection.
Copy and post here what you get on the Serial monitor
2- Can you please post here a screen copy of your Arduino IDE, after code compilation?
I'm asking for an image like the one below.
I may need more information, but for now the requested info will be enought.
Kind regards
(21-06-2020, 13:15)sarahdal Wrote:(20-06-2020, 22:11)Werk_AG Wrote: Copy and post here what you get on the Serial monitor
Kind regards
Thank you for taking the time to go through this with me. To clarify, when you say to compile, do you mean by the IDE's own Sketch -> verify/compile, or the ESP8266 Sketch Data upload?
