Hi All,
I wonder if anyone can help me with a problem uploading AQM data to ThingSpeak.
I'm running a WD Compact Rx (Software version WeatherDuino_P2ESP8266_RX_v4.0_b002) and have:
1) Enabled the TS upload:
2) Set the API key:
Which is definitely correct. Here it is copied from the channel - xxxxxxxxxxxxxxxxxxx
3) Enabled the internet connection and confirmed it is working.
4) Set up my ThingSpeak channel with four fields PM2.5, PM10, AQI and CO2 as per this thread: https://www.meteocercal.info/forum/Threa...ThingSpeak
However, I am getting no data appearing in the channel after 10 mins or more: https://thingspeak.com/channels/1082934
Any help with debugging this would be much appreciated.
Rgds,
Zak
EDIT by ADMIN: ThingSpeak WRITE key replaced by xxxxxxxxxxxxxxxxx
// Enable / Disable data transmission to ThingSpeak
#define ENABLE_TS_UPLOAD 1 // 1= Enable, 0= Disable2) Set the API key:
// ThingSpeak Credentials - Just needed if you want to upload data to a ThingSpeak channel
const char* TS_WRITEAPIKEY = "xxxxxxxxxxxxxxxxx"; // Put here your ThingSpeak WRITE key3) Enabled the internet connection and confirmed it is working.
Rgds,
Zak
