Quote:I've hooked it up to my cupless sensor and are getting at least the wind direction
You may now find if the wind direction readings are correct. The wind vane has a mark on is body. Point that mark to South. Manually rotate the vane to for N, E, S, and W. Check if the readings are correct. They must be. If necessary slightly adjust the value of R8 (it must be as close to 10K as possible).
Quote:I've also setup a dummy version of cumulus and that's working too.
I supose you are running the RX software in Davis VP2 emulation mode, right?
Quote:Just a couple of problems.
1) I'm getting UV and Solar rad fiqures without any sensors lol.
2) When I start Cumulus, the RX unit restarts and I get bad data until the units are all talking.
1) In TX software, comment this line:
//#define ID4
I think this will solve the problem.
2) Now it's time to talk about the VP1 switch. The VP1 switch is there exactly to prevents the auto-reset (this is a Arduino Nano feature, it auto-reset every time serial port is initialized) when Cumulus starts.
VP1 must be off, only when you install or upgrade RX software. After that, put VP1 switch on, wait at least 3 minutes to give time for the receiver get data from external sensors, and start Cumulus.
Let the RX unit working and forget... Now you can start and stop Cumulus every time is necessary.
Quote:EDIT:
3) Case T is always reading high at 74c (looks like it's actually reporting Fahrenheit)
Value is always the same? I will check this.
The System batterie voltage reading shows anything?
I ask because the two are sent on the same datapacket.
