27-08-2019, 20:39
@Werk_AG:
thanks for the note about the baud rate, now readable values are displayed.
I attach a screenshot to this message.
Today, the Ventus W044 sensor was delivered, I thought to shut down the Auriol unit, maybe that's not so easy. I had removed the batteries from the temperature / wind unit and then started the Pro2 Compact, actually it should stop when initializing, but the letter "T" emperature turned green. WTF? The Ventus sensor was not activated yet. Could another sensor disturb my operation here?
@engolling
it only spins the temperature and humidity values, but only the Pro2 Compact unit, the Auriol unit displays all values correctly.
The wind and rain values are displayed correctly everywhere.
The temp / humidity values on the Pro2 Compact constantly change between three-digit positive and negative ranges, as well as the correct display back and forth.
Weatherduino
greetings
@engolling
Weatherduino
greetings
