Temperature sensor problem
Hi everyone,
I have set TX,RX,WD... System is synchronized (time, presure,rain etc..), but temperature from TX DHT22 is not :/
In TX setup I have define DHT22, but still not working
#define TH_Sensor1 1 // [SENSOR 1] - 0 for SHT1x sensor, 1 for DHT22 sensor, 9 for Not Used
Any idea what ? Sensor is working, I test it on WDboard...
Hi ok2arm,
Could you post here the both whole config files - from TX and RX too?
(31-07-2018, 09:03)hornychz Wrote:  Hi ok2arm,
here is link for download, sry I Am not able send here...
https://we.tl/dwVGxeT7lu
But these are only the main code files, we need to see the config files ...
Oh, Sry Zdenek, again here...
https://we.tl/2tD8yPQgRt
Tnx
(31-07-2018, 11:54)ok2arm Wrote:  Oh, Sry Zdenek, again here...
Tnx
Hi ok2arm
Looking at your RX config I think you need to change the "Define type of your outside Temperture / Humidity sensor" from 0 to 1
Ouu, I Am I... Big Grin Thank !
So I need last two sensors, Rain and Wind, can you recommend something ?
Tnx
(31-07-2018, 17:21)ok2arm Wrote:  Ouu, I Am I... Big Grin Thank !
Tnx
Well I use fine offset rain and wind sensors, they're OK, maybe not the most accurate but they are cheap to buy and can usually be found on ebay.
Hi ok2arm
The cheapest ones are the fineoffset models. For the price they do a very good job.
Out of curiosity, can you post a picture of the backside of your TFT displays. I'm afraid that you could have some difficulties with the touch panel, at least with the WD unit.
(31-07-2018, 18:54)Werk_AG Wrote:  Hi ok2arm
Hi Werk,
WD unit work well, but RX unit... Sometimes touch not working, but this is not problem, because I need just main screen, also on the others unit...
Pls, can you send me exact rain/wind/direc unit from Ebay, maybee better for help after connection Smile
And, any idea how to connect bigger display for WD unit ?
Thank !!
