18-08-2019, 19:48
Hello WeatherDuino friends,
I have a Pro2 Compact with sensors of the Auriol HT13726 weather station. I have problems with the temperature and humidity sensor, apparently they are not recognized in between or show values in the three-digit minus or plus range. I wanted to play with the settings of the configuration files something, while the Duino is always flashed again. After flashing a few times, the Arduino IDE tells me that the memory is full even though I have selected to clear memory in the board configuration. I have tried the software via OTA and USB to flash, but now I can not continue. Can someone help me with the problems with the sensors and the flash process?
greetings
greetings
