AQM II dust sensor trouble
I have my AQM up and running with a Display, MH-Z19B SDS011 and SHT31 temp sensor.
Using software WeatherDuino_AQM_ESP8266_ASK_v120_b002
I am getting sensible readings back from the temp sensor and Co2 sensor ok, but the SDS011 gives the following response.
09:45:03.055 -> Waking up the dust sensor...
09:45:03.055 -> Reading will be done 40s later.
09:45:03.055 ->
09:45:43.034 -> Reading the dust sensor...
09:45:43.034 ->
09:45:44.036 -> EC,8A,FE,3F,1,0,0,0,94,6C,
09:45:44.036 -> Calculate crc: 3E
09:45:44.070 ->  Response crc: 94
09:45:44.070 ->
09:45:44.070 -> Wrong reply from SDS011 sensor!
There isn't much to show relevant to the dust sensor in the config options other than..
//   Define type of PM sensor
#define DUSTSENSOR_TYPE  1    // 0= PMS7003, 1= nova SDS011
I have tested the SDS011 with the manufacturers software and the USB to COM port adaptor that came with it and it works fine, so I know the sensor is ok.
I assume that I need to wire it up as follows.
AQM     SDS011
SET      TXD
TX        RXD
GND     GND
5V        5V
Grateful for any pointers!
Thanks Andy
(18-04-2019, 10:39)atbukc Wrote: I have my AQM up and running with a Display, MH-Z19B SDS011 and SHT31 temp sensor.
AQM     SDS011
SET      TXD
TX        RXD
GND     GND
5V        5V
Hello Andy,
I don't have SDS011, but I'd try to switch the wires TX and SET ...
Good luck!
AQM     SDS011
SET      TXD
TX        RXD
GND     GND
5V        5V
Hello Andy,
Good luck!
Perfect, all working fine now..
Thanks Andy.
