FO anemometer reading seems low
I have had my weather station up and running for a while now I am happy with most of the readings I am getting, except the wind speed,
which to me seems low
I am using FO anemometer which is freely rotating, hearing the 2 clicks/ticks per rotation, that I understand/believe you should get. I am using RX/TX v013 at present and using the settings as advised in the post RX/TX v013 Software configuration, speed is set to mph, multipliers 0,448.
any suggestions as to what the problem may be ?
regards
tyntop.
Is your anememoter mounted 10 metres above ground level in a "clear" field with no significant obstructions nearby?
Just to be clear, you have set the settings correctly in both the Weatherduino Pro2 sketch and Cumulus?
