22-05-2015, 20:38
I've begun to build Weatherduino pro2 RX. I preffer to use a 20X4 LCD.
This is my configuration data:
// User configurable options start here.
// --- Station ID, use the same value in your TX unit
const byte StationID = 0xA1;
// --- Define Software Operation Mode
#define Work_Mode 0 // Mode 0= Davis VP2 Emulation Mode, Mode 1= EasyWeather Mode
// --- Define your Display type
#define DisplayType 1 // 0= TFT, 1= LCD 20x4, 2= LCD 16x2
// --- Define Backlight timeOut
// --- With RX boards version <= 3.01 without the TFT backlight control mod, always set this value to 0
byte BackLight_Timeout = 0; // Timeout for TFT backlight in minutes (1 to 255). 0 = Always ON
// --- Define Temperature and Wind Display units
byte Temp_Display_Unit = 0; // 0 for ºC, 1 for ºF
byte Wind_Display_Unit = 0; // 0 for Km/h, 1 for mph, 2 for m/s
// --- Fine adjusts for Inside Temperature and Barometer
const int TemperaturaInt_offset = 0; // Inside Temperature Fine Adjust in Tenths of Degree (-4 = -0,4ºC)
const float pressure_offset = -1.0; // Pressure Fine Adjust in mB
// --- Some Data from your Weather Station location
#define LATITUDE 399 // Put here your Station latitude in tenths of degrees North
#define LONGITUDE 326 // Put here your Station longitude in tenths of degrees East
#define ELEVATION 900 // Put here your Station height above sea level in Meters
// --- Define Starting Hour of your Meteorological Day
#define MeteoDay_HStart 0 // Use values from 0 to 23
// --- Define Wind Speed and Wind Gust resolution
#define VP2_WindRes 2 // If set to 2, set Cumulus Wind Speed and Wind Gust multipliers to 0.448. Wind Resolution 0.72 Km/h
// If set to 1, set Cumulus Wind Speed and Wind Gust multipliers to 0.224. Wind Resolution 0.36 Km/h
// This setting only have effect when the software is used in Davis VP2 emulation mode
// --- Define type of outside temperature / humidity sensor
#define TH_OutSensor 1 // 0 for SHT21 or HTU21D sensor, 1 for SHT1x or DHT22 sensor,
// ---- Let's define the source of the sensors we want to receive
// ---- If you have all the sensors connected to only one TX board, always select Unit 0
#define TH_OutUnit 0 // 0 for Temp/Hum sensor connected to TX_Unit 0, 1 for Temp/Hum sensor connected to TX_Unit 1
#define WIND_OutUnit 0 // 0 for Wind instruments connected to TX_Unit 0, 1 for TX_Unit 1, 2 for Auriol RF Odometer
#define RAIN_OutUnit 0 // 0 for Rain Gauge connected to TX_Unit 0, 1 for TX_Unit 1, 2 for Auriol RF Rain Gauge
#define SRUV_OutUnit 0 // 0 for Solar Rad / UV sensors connected to TX_Unit 0, 1 for TX_Unit1
All parts (include AT45DB011) on the RX board has been mounted and arduino nano programmed. I want to test RX board functions so powered the board. But nothing displayed on the LCD. (I tried all address combinations.)
Any comments, helps please.
Regards.
Recep
Regards.
Recep
