Threads: 337
Country:
Thanks! That Var is no more used, I removed the declaration but forgot to remove another line on the code. I haven't noticed it because the error only comes up when compiling for very old TFT displays.
Its fixed now. Onve again thank you.
Threads: 337
Country:
Just for curiosity. Even though it's an old display, have you tried it with the "0" option? In many cases the calibration procedure after the first firmware upload works.
Threads: 18
Weather Station: ILEIPZ27
Country:
Hello and sunny greetings,
can the latest firmware be checked please, the screen saver does not activate. Various time outs or changing the mode did not bring any changes..
many thanks and kind regards!
Threads: 337
Country:
Hello dear Sun_Dancer
For me to check, can you please specify to which firmware do you refer? Firmware for the older WD unit, or for the newer WD II units?
Kind regards
