30-07-2019, 13:40
Ever since I first started up my WeatherDuino system I've had bad luck with failing temp/humid sensors.
I've been using the SHT31D sensors.
They only last a few months before failing, with the suspicion being that the break out board starts to corrode which leads to the failure.
2 years ago I started putting the sensor in a plastic enclosure for a bit more protection, it helped. But still the sensors failed.
Last year I got some Closed Cube versions with the screen/filter protection. I also sprayed the break out PCB after the cable has been soldered with clear lacquer for protection from corrosion (covered the sensor sensing hole before applying the clear lacquer).
The last sensor lasted a year before failing again. No apparent water or corrosion damage that I could see.
What is the reliability like for other members?
What do you do or how do you protect the sensors?
Some pictures for reference of the installation of the last failed sensor.
![[Image: IMG_20190502_142904-upr-sm.jpg]](https://meteo.brandysnl.cz/MyDocs/Forum/IMG_20190502_142904-upr-sm.jpg)
![[Image: DSC_8579-upr-sm.jpg]](https://meteo.brandysnl.cz/MyDocs/Forum/DSC_8579-upr-sm.jpg)
