06-03-2019, 02:47
(06-03-2019, 02:24)richaam Wrote: Thanks guys,
I will order a new one and report back. Are the 4 pin senors the best option? Some higher quality companies like Adafruit sell the sensor but they seem to be mostly 6 pins.
-Adam
The Adafriut 6 pin ones can do SPI as well as I2C. They also would allow you to change the I2C address.
The only benefit would be if you wanted to run 2 simultaneously.
