05-02-2019, 18:08
I have just received my Wireless display unit, I have configured it to use a BME280 sensor for internal temperature, on compiling it gives errors, after a bit of research it seems that the code is only compatible with version 1.0 of the BME280 library, not the version 2.30 supplied with downloaded lib pack, I have compiled with the v1.0 lib and it compiles and uploads fine, however the internal temp is displayed as 0.0 and the humidity as 0.0%, I have tested the sensor with example code & its fine..
If someone could help me with this I’d be grateful.
Thanks Andy
Thanks Andy
