Threads: 15
Country:
Hi all
One thing I haven't really seen detailed is the outdoor temp/humidity sensor. I see a spot for the TMP36 on my Tx unit but I want outdoor temp and humidity. I ordered an extra BME280, can I just connect that to the I2C bus connector next to the solar/UV connector and use that? Will the baro just be ignored on that unit? (I'll use the indoor BME280 baro)
Colin
Threads: 15
Country:
17-09-2018, 04:46
(This post was last modified: 17-09-2018, 04:49 by
41south.)
Thanks, the SHT-31 it is then. Luckily found one locally
And confirming that can just go onto the I2C bus connector?
The LSDA/LSCL is the extended I2C bus?
Colin
Threads: 337
Country:
Preferably use the LSDA/LSCL connector. It allows the use cables with a greater length between the sensor and the TX interface.
Threads: 15
Country:
18-09-2018, 01:41
(This post was last modified: 18-09-2018, 01:41 by
41south.)
Will do, thanks.
It seems that the I2C extender chip used is going to be hard to get at some stage in the future. Farnell/Element14 have told me that they are now out of production, although they do have 5000 in stock! I did find smd versions but I'm not sure on the production life of those.
Another quick question - is there any problem with splitting the normal weather devices across 2 Tx units? I may have to put the wind device on 1 Tx unit and the rest of the devices on another (rain/temp/hum etc)
Colin
Threads: 22
Weather Station: Wetterstation Engolling
Country:
according to the sensirion page the SHT85 is based on a SHT3x-Sensor.
This means by selecting SHT31 in the software it will work.
