Threads: 66
Country:
We had some rain today,the first in many months, but my receiver did not indicate it. I am wondering if the fact that my Tx is running software v6 b004 and my Rx is running v6 b014 has anything to do with it?
Threads: 31
Weather Station: Conder Weather, Canberra
Country:
Hi Jim,
I'll give you my thoughts until Werk can possibly answer.
While I don't know if the packet stream has changed in-between those versions it's quite possible.
Usually Werk notes what works with what in the release note.
Anyway, it's a good idea to keep both ends up to date or at least at the same firmware version.
Cheers UB
Threads: 66
Country:
Werk
We actually had in excess of 12mm according to my old style gauge mounted in my courtyard but I have been unable to access the roof to see if there is a mechanical blockage in the Davis gauge which prevented the gauge recording it.I had an issue before where the birds were sitting on the wind vane arm and their droppings were going into the rain gauge and blocked the strainer and prevented it from reading (since fixed). Thinking about the minor reading it is only one “tip” and it could have been caused by mast vibration
It will have to wait until I am able to climb the access ladder and update the software and look it over.
