WD Pro4 Weather Display
Can you please advise the pin-out for the T/H sensor connector and the sensors suitable for use with the unit
Hi Jim,
On the software package for the WD Pro4 Weather Display, there is folder called pinout, there you can find an image with the pinout for the T/H sensor.
Regarding the supported sensors, please give a look at the software user configurable options:
// --- Define type of Local TH sensor #define INSIDE_TH_SENSOR     9      // 0= BME280, 1= HTU21D, 2= SHT21, 3= SHT31, 9= Use Main Station TH sensor
Preferably use the 3.3V versions. For the WD, I would recommend the SHT31, quality/price is the best.
