AQ monitor_odd reading
[attachment=1306] WeatherDuino 4Pro
Air Quality Monitor v7.10 b003
Please wait...
Waking up the PMS7003 dust sensor (40s)
Reading PMS7003 dust sensor...
PMS7003 readings:
PM2.5: 1.00 ug/m3
PM10 : 1.00 ug/m3
PM2.5_1H_Avg : 1.00
PM2.5_NowCast: 1.00
I got this odd reading in the PM2.5 field and a AQI of zero. If I reboot it comes good for an indeterminate time and the n comes back. Most annoying
Any ideas anyone?
Can you please tell which software version are you using?
(10-02-2018, 03:15)Werk_AG Wrote:  Can you please tell which software version are you using?
V7.1 b003
I am having a similar experience using AQ software 7.0 b007. I started experiencing this when I moved the monitor outside and placed under our pergola. It has been extremely hot here over the last month so I am wondering if this may be the cause. The pergola is partially enclosed and runs a couple of degrees hotter than outside.
Ian
(10-02-2018, 05:31)dormani Wrote:  I am having a similar experience using AQ software 7.0 b007. I started experiencing this when I moved the monitor outside and placed under our pergola. It has been extremely hot here over the last month so I am wondering if this may be the cause. The pergola is partially enclosed and runs a couple of degrees hotter than outside.
Ian
It is now happening every time I boot the AQ monitor, so i changed the sensor and it gives the same response on the serial monitor shown below. I find it difficult to believe I have two faulty sensors bought some months apart.
WeatherDuino 4Pro
Please wait...
PMS7003 readings:
PM2.5: 0.00 ug/m3
PM10 : 0.00 ug/m3
PM2.5_1H_Avg : nan
PM2.5_NowCast: nan
Ian
WeatherDuino 4Pro
Please wait...
PMS7003 readings:
PM2.5: 0.00 ug/m3
PM10 : 0.00 ug/m3
PM2.5_1H_Avg : nan
PM2.5_NowCast: nan
Ian
WeatherDuino 4Pro
Please wait...
PMS7003 readings:
PM2.5: 0.00 ug/m3
PM10 : 0.00 ug/m3
PM2.5_1H_Avg : nan
PM2.5_NowCast: nan
I re downloaded the software from the website and all is now good. My laptop which I usually use for WeatherDuino is in for repair and I have been using my desktop in the meantime.
Maybe that had something to do with it
Thank you both for reporting this issue.
The NaN error happens due to a division by zero when the PM2.5 readings are also zero. Getting PM2.5 readings equal to zero is a very unlikely situation. Despite of this I already did some changes on the AQM software to deal with that situation. The updated software (v7.10_b004) is already available for download.
Jim, as it seems you are getting frequent PM2.5 readings equal to zero, please check all the connections to the sensor. Verify if when you get the message "Waking up the PMS7003 dust sensor (40s)" the fan starts to spin.
(10-02-2018, 23:04)Werk_AG Wrote:  Hi,
I ran the serial monitor and verified that the fan does spin at the "waking up sensor (40s)" (Code shown below)
I just noticed the latest software is available and will install it shortly
Thanks again for your prompt assistance,
WeatherDuino 4Pro
Please wait...
PMS7003 readings:
PM2.5: 0.90 ug/m3
PM10 : 1.80 ug/m3
PM2.5_1H_Avg : 0.90
PM2.5_NowCast: 0.90
Thanks Jim,
Things improve with the users feedback.
Now, any PM2.5 reading equal to zero, will not cause the NaN error anymore.
