2PLUS_v3.2_b001
Just upgraded to v3.2_b001. Everything appears normal except on the system info screen, it says "check for latest software is disabled".
The internal web page System Info screen says,
"WEATHERDUINO PRO2 PLUS ™ - 2PLUS_v3.2_b001
Latest available version: 2PLUS_v3.2_b001"
but on the receiver system info page it still says "check for latest software is disabled"
other than that everything else appears to be working fine.
Is it enabled in the config?
(18-09-2017, 08:00)uncle_bob Wrote:  Is it enabled in the config?
I don't know since I never enabled or disabled it on this or previous versions.
I did a search for "version" and found this in the "NET" tab, but nothing in the config tab
//     Software Version Checker
#if (Enable_Internet == 1)
void check_SoftwareVersion()
  static uint8_t mux_id = 4;
  String DevModel = String(Board_Version / 10.0, 1) + "-" + DeviceModel;
  char HTTP_response[250];
  memset(HTTP_response, 0, sizeof(HTTP_response));
String Data = "GET /WD_services/VCheck/LastVersionCheck.php?";
  Data += "ID=";
  Data += DevID;
  Data += "&model=";
  Data += DevModel;
  Data += "&softver=";
  Data += SoftwareVer;
  Data += "&lt=";
  Data += String(LATITUDE, 3);
  Data += "&lg=";
  Data += String(LONGITUDE, 3);
  Data += " HTTP/1.0\r\n";
  Data += "Host: ";
  Data += "weatherduino.com";
  Data += "\r\n";
  Data += "Connection: close\r\n\r\n";
// Create connection with the WeatherDuino Server
  if (wifi.createTCP(mux_id, "weatherduino.com", 80, 0))
    #ifdef PRINT_DEBUG_VCHECK
      Serial.println(F("Checking for latest software version..."));
    #endif
    const char *PacketToSend = Data.c_str();
    wifi.send(mux_id,(const uint8_t*)PacketToSend, strlen(PacketToSend));
    uint8_t buffer[250] = {0};
    uint16_t len = wifi.recv(mux_id, buffer, sizeof(buffer), 2000);
    if (len > 0)
      for(uint16_t i = 0; i < len; i++)
        HTTP_response[i] = (char)buffer[i];
      char * content = strstr(HTTP_response, "\r\n\r\n");
      if (content != NULL)
        content += 4;
        LatestSoftwareVersion = content;
        //VCheck = true;
          Serial.print(F("Latest software version: ")); Serial.println(LatestSoftwareVersion);
        #endif
  wifi.releaseTCP(mux_id);
#endif
It's a new feature, I have to enable it ...
(18-09-2017, 08:52)hornychz Wrote:  It's a new feature, I have to enable it ...
Yes and no. Ver3.1 had it and I didn't have to enable it. I didn't see where to enable it on Ver3.2.
I just looked at the config again and cannot see where to enable or disable it. Care to tell me where it is?
I saw it in there earlier. Let me download it and take a looksee.
I can only find what you already posted, sorry.
Might have to wait for the boss or Horny have some say.
In the meantime maybe uncomment this part //#define PRINT_DEBUG_VCHECK
and check the serial monitor (at 19200 baud) and see if that may help troubleshoot?
I found only the same as you:
//--------------------------------------------------------- //     Software Version Checker //--------------------------------------------------------- #if (Enable_Internet == 1) void check_SoftwareVersion() { ....
I think it means you have to only enable internet and nothing more ...
(Now I am at my customer, I can not do more. Maybe Werk_AG will answer,
or in my evening I can see it again.)
