I did a search here and on the internet and I am seeing conflicting information regarding how to wire my i2c SHT31 temp sensor. I plan to use some Cat5 cable that I have.
On a search of this site I found reference to twisting the VCC with SCL and twisting the Gnd with SDA.
On the internet I found reference to twisting the SCL and SDA together and VCC and SCL together.
And finally on another website I found reference to twist VCC with SDA and Gnd with SCL. I found that here. https://electronics.stackexchange.com/qu...-vs-p82b96
Suggestions:
So needless to say I am a little confused. On 1 of my Tx boards I have installed the 82PB715 chip so I assume the SHT31 will get plugged into the EI2C port? Do I have to get another 82PB715 and install it at the SHT31 end of the CAT5 cable or is 3ft of cable ok to use with just the single 82PB715 on the Tx board?
TIA
Suggestions:
- Use 5V not 3.3V. Use I2C slaves (CMOS levels) not SMBUS that have TTL input levels
- Use a shielded or twisted cable
- DON'T put SDA, SCL together, especially don't twist them together. Twist SDA with VCC and SCL with GND, and have 100nF between VCC and GND at each end. (If you look carefully in the 82B96 circuit you will see that NXP show the bus wires arranged this way.)
TIA
