02-10-2015, 08:13
I got my single Tx unit and Rx unit all connected up last weekend, but I have been having comms problems ever since, after only about 6 - 12hrs of operation.
My Tx unit is mounted on the outside of bedroom, which has a mixture of wooden and stucco exterior. The Tx unit is powered by a 12v connection. The Rx unit is in my bedroom, only about 4m away from the Tx unit.
I start my Rx unit with both the USB and power connected and see a regular pulse on the Tx LED, at least every 5 seconds. After 6 - 12 hrs of operation, the Tx LED on my Rx unit is only flashing every couple of minutes. The data showing on the Rx unit LCD does not change.
Whilst the Rx unit is in the state where it does not appear to be receiving the regular updates from the Tx unit, I am able to press the switch connected to the PB pins, to turn on the LCD backlight and show the data. Therefore the Rx unit does not appear to be locked up.
I have tried adding a 17.3cm piece of wire to the antenna connection for the Tx unit's FS1000 board, but after doing this I got no connection at all from the Tx unit. I have tried moving the Rx unit closer and further away from the Tx unit, with no improvement of the problem.
I have resoldered the connections for the antenna connected to the Rx unit and have checked the solder connections to the receiver board, but do not see a problem.
Apart from this communication problem between the Rx and Tx unit, everything else is working perfectly.
Any help or advice as to what to check, would be much appreciated.
![[Image: FS1000A_Antenna.jpg]](http://www.meteocercal.info/forum/images/01forum_img/FS1000A_Antenna.jpg)
