Take the most of your hardware
(22-03-2018, 03:14)uncle_bob Wrote:  Hi Jim,
Looks good.
Just commenting till Werk's up..
Did you also update the AQM software too?
Cheers UB
UB,
Yes I did;really wierd the AQM reports well to the Rx but appears not to get sent to the WD’s
(22-03-2018, 03:08)Barrow4491 Wrote:  They both seem to have extra data displayed (The menu screen has a temp and Rh displayed in the bottom right  and the other has an extra date and time)
Hi Jim,
Since we have now a menu screen, allowing us to jump directly to a particular data screen, the function to hide a particular data screen doesn't make sence anymore, so I have removed it, but I forgot to remove the text, "(Use 9 to prevent a particular data screen to be shown)" from the Config_Options.h file
Its already corrected, and should be:
// -------------------------------------------------------------------------------------- //   Define display order of data screens on the TFT //   Use numbers from 1 to 4. // -------------------------------------------------------------------------------------- #define AirQuality_Data    1 #define TXinfo_Data        2 #define ExtraSensors_Data  4 #define SoilLeaf_Data      3
Hi Jim,
Since now we have a menu system, allowing us to jump directly to a particular data screen, the function to hide a particular data screen doesn't make sence anymore, so it was removed.
I have reloaded the modified software and the problem with the temp/rh on the menu screen is fixed but I can still create the extra date and time on the screen blanker by touching the r/h side top of the screen repeatedly.
It doesn't bother me as I know how to avoid it an the screen saver works fine.
My issue is with the AQ data not being relayed to the WD units, but all other data is.
I have attached my config file and verified that the board is pro 2 v2.21
// -------------------------------------------------------------------------------------- //       WeatherDuino Wireless Display //       Version: AT328_WD_v6.0-b002 //        User configurable options // -------------------------------------------------------------------------------------- // -------------------------------------------------------------------------------------- //   Define the ID for the Wireless Display Units //   Relay_ID should be equal to the value set in your Main RX software // -------------------------------------------------------------------------------------- const byte Relay_ID = 0xA3; // -------------------------------------------------------------------------------------- //   Define Interface Language // --------------------------------------------------------------------------------------       #include "_lang/en_GB.h"      // Change the language code according to your preference. Keep "_lang/" and the ".h" at the end                              // Currently available languages: en_GB, fr_FR, de_DE, pt_PT, es_ES, cs_CZ, nl_NL, it_IT // --- Define if your ILI9341 TFT Display have touch capabilities // --- ATENTION! Only WD boards v2.20 (released in 2015) or greater have hardware support for the touch panel // --- A TFT with a touch panel is highly recommended #define Touch_Display         1      // 0= Display without touch panel, 1 = Display with touch panel // --- Define Backlight timeOut byte BackLight_timer        = 0;    // Timeout for TFT backlight in minutes (1 to 255). 0= Always ON // --- Define type of Local TH sensor #define InsideTH_Sensor       0      // 0= DHT22, 1= HTU21D, 2= SHT21, 3= SHT31, 9= Use Main Station TH sensor // --- Fine adjusts for Local Inside Temperature int TemperaturaInt_offset =   0;     // Inside Temperature Fine Adjust in Tenths of Degrees // ---- Define personalized names for each Extra Sensor. Attention, maximum 8 chars, const char ESname_1[] PROGMEM = "Telhado";     // 8 chars max const char ESname_2[] PROGMEM = "LagoAgua";    // 8 chars max const char ESname_3[] PROGMEM = "Alpendre";    // 8 chars max const char ESname_4[] PROGMEM = "Main Out";    // 8 chars max const char ESname_5[] PROGMEM = "SENSOR 5";    // 8 chars max const char ESname_6[] PROGMEM = "Dust TH";     // 8 chars max const char ESname_7[] PROGMEM = "";            // 8 chars max // ---- Define personalized names for each Soil and Leaf Sensor. Attention, maximum 8 chars const char SSname_1[] PROGMEM = "Relva";        // 8 chars max const char SSname_2[] PROGMEM = "";             // 8 chars max const char SSname_3[] PROGMEM = "";             // 8 chars max const char SSname_4[] PROGMEM = "BIOS";         // 8 chars max const char LSname_1[] PROGMEM = "Folhas";       // 8 chars max const char LSname_2[] PROGMEM = "";             // 8 chars max const char LSname_3[] PROGMEM = "";             // 8 chars max const char LSname_4[] PROGMEM = "";             // 8 chars max // -------------------------------------------------------------------------------------- //   Define display order of data screens on the TFT //   Use numbers from 1 to 4. Use 9 to prevent a particular data screen to be shown // -------------------------------------------------------------------------------------- #define ExtraSensors_Data 3 #define SoilLeaf_Data     4 #define AirQuality_Data   1 #define TXinfo_Data       2 /*************************************************************************************     Hardware Settings *************************************************************************************/ // -------------------------------------------------------------------------------------- //   Define PCB Version Number // -------------------------------------------------------------------------------------- //                              Take particular attention to this setting. //                              Your system, specially the touch screen may not work properly if you define a wrong pcb version number. //                              In case of doubt check what is printed in your pcb. #define Board_Version    2   // PCB version number (integer part only): 2, 3 or 4, 0= Others (Old RX converted boards) // SHT31 I2c Address // Default address will work most of the times! #define SHT31_address 0x44      // Default value is 0x44, but it can be changed to 0x45 // --------------------------------------------------------------------------------------------------- //     End of user configurable options // ---------------------------------------------------------------------------------------------------
(23-03-2018, 03:43)Barrow4491 Wrote:  Werk,
Indeed it can happens, thanks. It will be fixed in b010.
Any ideas on the AQ data issue not loading to the wireless display units
Hi Jim
Today I did a lot of tests with all my Wireless Display units, and still couldn't reproduce this issue.
All units are receiving AQM data from the main receiver.
Do you receive any data from the AQM as Temp / Hum or nothing reaches the WD ?
(24-03-2018, 02:36)Werk_AG Wrote:  Hi Jim
I have attached a couple of screen shots which are self explanatory
Hi Jim,
I still haven't an explanation for this situation, but surely there is one.
Is this situation happen to anyone else? Anybody that is already using v6 software and have Wireless Display units, please report if they are fully working or not. Thanks
Hi Jim,
I have looked at everything but am at a total loss too!! All I know is that it was working with the previous v5 software
Kind regards
Hi Jim
Would it be beneficial to upload a zip file of all the V6.0 software you are using so the complete build could be tried and replicated across all platforms?
Just remember to remove your private data like WeatherUnderground, WiFi passwords etc before making this public for others to look at.
Just a thought.
PalmyWeather
