LCD display_AQ
I changed the LCD screen on my Air Quality unit today and the new one will not display data. I reloaded the latest software and get the following compile error
Arduino: 1.8.5 (Windows 10), Board: "Arduino Nano, ATmega328P" C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\JBA\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10805 -build-path C:\Users\JBA\AppData\Local\Temp\arduino_build_921919 -warnings=none -build-cache C:\Users\JBA\AppData\Local\Temp\arduino_cache_911801 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Users\JBA\Documents\Arduino\WeatherDuino_Pro2_PLUS\v5.0\software\AQM software\WeatherDuino_AirQualityMonitor_PMS_v710_b001\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\JBA\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10805 -build-path C:\Users\JBA\AppData\Local\Temp\arduino_build_921919 -warnings=none -build-cache C:\Users\JBA\AppData\Local\Temp\arduino_cache_911801 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Users\JBA\Documents\Arduino\WeatherDuino_Pro2_PLUS\v5.0\software\AQM software\WeatherDuino_AirQualityMonitor_PMS_v710_b001\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino Using board 'nano' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr Using core 'arduino' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr Detecting libraries used... "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\JBA\AppData\Local\Temp\arduino_build_921919\sketch\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "C:\Users\JBA\AppData\Local\Temp\arduino_build_921919\sketch\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\JBA\AppData\Local\Temp\arduino_build_921919\sketch\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\JBA\AppData\Local\Temp\arduino_build_921919\sketch\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Users\JBA\AppData\Local\Temp\arduino_build_921919\sketch\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "C:\Users\JBA\AppData\Local\Temp\arduino_build_921919\sketch\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "C:\Users\JBA\AppData\Local\Temp\arduino_build_921919\sketch\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "C:\Users\JBA\AppData\Local\Temp\arduino_build_921919\sketch\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "C:\Users\JBA\AppData\Local\Temp\arduino_build_921919\sketch\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\AppData\Local\Temp\arduino_build_921919\sketch\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHCRC.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHDatagram.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHEncryptedDriver.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHGenericDriver.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHGenericSPI.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHHardwareSPI.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHMesh.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHNRFSPIDriver.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHReliableDatagram.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHRouter.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHSPIDriver.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHSoftwareSPI.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_ASK.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_CC110.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_E32.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_MRF89.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_NRF24.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_NRF51.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_NRF905.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_RF22.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_RF24.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_RF69.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_RF95.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_TCP.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src\Wire.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\Timer\Event.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\Timer\Timer.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31\Adafruit_SHT31.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\SHT21\SHT2x.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\HTU21D\HTU21D.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src\SoftwareSerial.cpp" -o "nul" Generating function prototypes... "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\AppData\Local\Temp\arduino_build_921919\sketch\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_921919\preproc\ctags_target_for_gcc_minus_e.cpp" "C:\Program Files\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\JBA\AppData\Local\Temp\arduino_build_921919\preproc\ctags_target_for_gcc_minus_e.cpp" Compiling sketch... "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\AppData\Local\Temp\arduino_build_921919\sketch\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_921919\sketch\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino.cpp.o" C:\Users\JBA\Documents\Arduino\WeatherDuino_Pro2_PLUS\v5.0\software\AQM software\WeatherDuino_AirQualityMonitor_PMS_v710_b001\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino: In function 'void setup()': WeatherDuino_AirQualityMonitor_PMS_v710_b001:236: error: no matching function for call to 'LiquidCrystal_I2C::begin()'    lcd.begin();              ^ C:\Users\JBA\Documents\Arduino\WeatherDuino_Pro2_PLUS\v5.0\software\AQM software\WeatherDuino_AirQualityMonitor_PMS_v710_b001\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino:236:14: note: candidate is: In file included from C:\Users\JBA\Documents\Arduino\WeatherDuino_Pro2_PLUS\v5.0\software\AQM software\WeatherDuino_AirQualityMonitor_PMS_v710_b001\WeatherDuino_AirQualityMonitor_PMS_v710_b001.ino:38:0: C:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h:58:8: note: void LiquidCrystal_I2C::begin(uint8_t, uint8_t, uint8_t)   void begin(uint8_t cols, uint8_t rows, uint8_t charsize = LCD_5x8DOTS );        ^ C:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h:58:8: note:   candidate expects 3 arguments, 0 provided Using library RadioHead in folder: C:\Users\JBA\Documents\Arduino\libraries\RadioHead (legacy) Using library SPI at version 1.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI Using library Wire at version 1.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire Using library LiquidCrystal_I2C at version 1.1.2 in folder: C:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal_I2C Using library Timer in folder: C:\Users\JBA\Documents\Arduino\libraries\Timer (legacy) Using library Adafruit_SHT31 at version 1.0.0 in folder: C:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31 Using library SHT21 in folder: C:\Users\JBA\Documents\Arduino\libraries\SHT21 (legacy) Using library HTU21D in folder: C:\Users\JBA\Documents\Arduino\libraries\HTU21D (legacy) Using library SoftwareSerial at version 1.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial exit status 1 no matching function for call to 'LiquidCrystal_I2C::begin()'
I noticed the chips are different on the I2C modules The original is PFC8574T and the replacement is PFC8474AT.
I cant get the unit to boot at all now
JIm
Hi Mike
It isn't due to having changed of the LCD, that you started to get compile errors, it must be something else.
Check if you haven't changed the library, or if you are using the one suplied with the software.
Your new LCD may have a diferent I2C address than the one defined by default, however this not cause any compile error, just the LCD doesn't display any data until you set the correct I2C address.
If you don't know the I2C address of the new LCD, use the I2C scaner utility. By defaut it is set to 0x27
By the way, latest AQM software is v7.1_b003
(01-02-2018, 04:42)Werk_AG Wrote:  Hi Mike
Werk
Sorted it out.Yesterday I was working on another project which needed "LiquidCrystal_I2C" and the one supplied with your software is named "LiquidCrystal-I2C", so I had both in the Arduino library.
When compiling it opted to use the more conventionally named one with the underscore rather than the dash.
I have deleted the other and changed the address to 0x3F and all is good now
Good stuff Jim.
I was just going to post that my LCD has a 0x3F address also.
(01-02-2018, 11:33)uncle_bob Wrote:  Good stuff Jim.
Uncle_bob
The problem is the two libraries cannot co exist. A pity there is not one to cover all possibilities but it looks like I will have to delete and reinstall as needed
(01-02-2018, 22:04)Barrow4491 Wrote:  Uncle_bob
Jim, Check this thread out: http://www.meteocercal.info/forum/Thread...rtable-app
