RX V5 upload error
(20-01-2018, 05:21)Werk_AG Wrote:  Jim, the compiler output on your previous post is from the TX software compilation. Is the upload problem with the TX or with the RX software?
When changing compiling for the Nano to the Mega, check if you don't have to change the com port.
Sorry I attached the wrong code. I am suspending the upgrade until I resolve the UV issue
I have upgraded my spare Tx with V5 and all good. I will swap it out when I get the Rx sorted.
I tried to upload to my spare Rx but the compile aborted
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)" C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\JBA\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10805 -build-path C:\Users\JBA\AppData\Local\Temp\arduino_build_14249 -warnings=none -build-cache C:\Users\JBA\AppData\Local\Temp\arduino_cache_937216 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Users\JBA\Documents\Arduino\WeatherDuino_Pro2_PLUS\v5.0\software\RX software\WeatherDuinoPro2Plus_RX_v500_b002_21012018\WeatherDuinoPro2Plus_RX_v500_b002_21012018.ino C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\JBA\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10805 -build-path C:\Users\JBA\AppData\Local\Temp\arduino_build_14249 -warnings=none -build-cache C:\Users\JBA\AppData\Local\Temp\arduino_cache_937216 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Users\JBA\Documents\Arduino\WeatherDuino_Pro2_PLUS\v5.0\software\RX software\WeatherDuinoPro2Plus_RX_v500_b002_21012018\WeatherDuinoPro2Plus_RX_v500_b002_21012018.ino Using board 'mega' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr Using core 'arduino' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr Detecting libraries used... "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\mega" "C:\Users\JBA\AppData\Local\Temp\arduino_build_14249\sketch\WeatherDuinoPro2Plus_RX_v500_b002_21012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Users\JBA\Documents\Arduino\libraries\Timezone\src" "C:\Users\JBA\AppData\Local\Temp\arduino_build_14249\sketch\WeatherDuinoPro2Plus_RX_v500_b002_21012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Users\JBA\Documents\Arduino\libraries\Timezone\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Time" "C:\Users\JBA\AppData\Local\Temp\arduino_build_14249\sketch\WeatherDuinoPro2Plus_RX_v500_b002_21012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Users\JBA\Documents\Arduino\libraries\Timezone\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Time" "C:\Users\JBA\AppData\Local\Temp\arduino_build_14249\sketch\WeatherDuinoPro2Plus_RX_v500_b002_21012018.ino.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_14249\preproc\ctags_target_for_gcc_minus_e.cpp" In file included from C:\Users\JBA\Documents\Arduino\WeatherDuino_Pro2_PLUS\v5.0\software\RX software\WeatherDuinoPro2Plus_RX_v500_b002_21012018\WeatherDuinoPro2Plus_RX_v500_b002_21012018.ino:41:0: C:\Users\JBA\AppData\Local\Temp\arduino_build_14249\sketch\Config_RX_Pro2PLUS.h:44:126: fatal error: _lang/en_GB.h: No such file or directory #include "_lang/en_GB.h"      // Change the language code according to your preference. Keep "_lang/" and the ".h" at the end        ^ compilation terminated. Using library Timezone at version 1.1.1 in folder: C:\Users\JBA\Documents\Arduino\libraries\Timezone Using library Time at version 1.5 in folder: C:\Users\JBA\Documents\Arduino\libraries\Time exit status 1 Error compiling for board Arduino/Genuino Mega or Mega 2560.
Re version 5 upgrade
I upgraded my spare Tx to V5 with no issues and will swap it when I get the Rx done; I have a compile issue with it
PHP Code:
C
Using board
Using core
exit status 1
Error compiling
I am sorry to annoy you.
Quote:C:\Users\JBA\AppData\Local\Temp\arduino_build_14249\sketch\Config_RX_Pro2PLUS.h:44:126: fatal error: _lang/en_GB.h: No such file or directory
The compiler is giving you a clue...
Most probably you haven't fully copied the WeatherDuino Pro2 Plus software. The folder with the language files is missing.
Hello Jim,
downloaded the software file again with the same result??
Jim, when you edit and save the software with a different name (and you did it), IDE creates a new folder. The languages folder isn't copied automatically, you should copy it manually.
(21-01-2018, 04:45)Werk_AG Wrote:  Jim, when you edit and save the software with a different name (and you did it) , IDE creates a new folder. The languages folder isn't copied automatically, you should copy it manually.
Thanks, i was unaware of that
All units updated to V5 and only issue is my rainfall reading is 13052 mm (i wish!!) How do I fix this??
May be worth a general note to all about renaming files
(21-01-2018, 05:44)Barrow4491 Wrote:  my rainfall reading is 13052 mm (i wish!!) How do I fix this??
I had the same problem.
Angel Turns out I didn't read the instructions and to turn off the logger in Cumulus before updating Angel
Anyway, just set your 'todays rain' to 0 and clean up the data in WU tomorrow if you use WU.
Uncle_bob,
I didn’t  either but in Cumulus the gauge reading is zero and the edit function shows zero as well.
Since I updated today, I am not connecting to WU(according to the Wunderground app)and the ntp server light remains red as well. I have tried various other ntp servers, checked my settings and reloaded with no change. Could you let me know which ntp server you use. I never had these issues with V4
